BAQ report in 9.05 not showing
"Allow All Territories" fixed the problem.
Thank You
--- In vantage@yahoogroups.com, "b_ordway" <cooner_55421@...> wrote:
> > If you use CRM - is the user's workforce record set up correctly?
> > Just a guess.
> I'll second that guess.
> You can try checking "Allow All Territories".
> --- In vantage@yahoogroups.com, "P" <pklein@> wrote:
> > Are you using CRM?
> > If you are using CRM, and you remove the SHIPTO table - will it for that user?
> > just a guess.
> > --- In vantage@yahoogroups.com, "abcdefgsaga" <Adam.Gwizdz@> wrote:
> > > Hello,
> > > I have one user that tries to run a BAQ report but nothing shows up.
> > > I know the report works because others are able to run it.
> > > Is there any setting that must be turned on for this user?
> > > Please help!
Hello,
Please help!
Is it shared? What tables - does he/she have permissions to those tables?
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of abcdefgsaga
Sent: Tuesday, June 26, 2012 2:39 PM
Subject: [Vantage] BAQ report in 9.05 not showing
Hello,
Please help!
Are they running the Query or the Report?
Do they need to enter a criteria if it is a report and is it within the parameters of the query?
Miguel A. Santillan
Compass Components, Inc.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Karen Schoenung
Sent: Tuesday, June 26, 2012 12:56 PM
Subject: RE: [Vantage] BAQ report in 9.05 not showing
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of abcdefgsaga
Hello,
Please help!
It is shared.
The BAQ includes the following tables:
Customer
OrderDtl
OrderHed
OrderRel
Part
PartDtl
ProdGrup
ShipTo
Where do I set permission to him to run this report?
> Hello,
> Please help!
System Mgmt, in Security Maintenance, Menu Maintenance - Security tab, see which groups have permissions - he has to be in one of those groups or have his own permission (not the best option).
Sent: Tuesday, June 26, 2012 3:14 PM
Subject: [Vantage] Re: BAQ report in 9.05 not showing
It is shared.
Customer
OrderDtl
OrderHed
OrderRel
Part
PartDtl
ProdGrup
ShipTo
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, Karen Schoenung <kschoenung@...<mailto:kschoenung@...>> wrote:
> Hello,
> Please help!
Are you using CRM?
just a guess.
--- In vantage@yahoogroups.com, "abcdefgsaga" <Adam.Gwizdz@...> wrote:
> Hello,
> Please help!
> Just a guess.
--- In vantage@yahoogroups.com, "P" <pklein@...> wrote:
> Are you using CRM?
> just a guess.
> > Hello,
> > Please help!
Also, a thing to look at is Authorized Users. We are on 607. I was running BAQs, and I could only see 76 of our customers. I found that I was somehow an authorized user on some inactive rep in Workforce. When I removed myself, I, then, saw all customers in that same BAQ.
--Matt
> > Just a guess.
> > Are you using CRM?
> > just a guess.
> > > Hello,
> > > Please help!
