Hi everyone,
I thought I'd let you all know that this is now working.
The bottom line is that the code page suggested in Epicor's guide on MS SQL for enabling support of the Euro currency symbol is totally wrong. Something completely different needs to be place dinto the Progress '.pf' files.
Thanks.
Thanks.
--- In vantage@yahoogroups.com, "Clive" <clive.1972@...> wrote:
> Hi,
> We went live with Epicor 9.05.700C (64 bit MS SQL) yesterday after many months of preperation, but we've hit a problem that's never happened to us before.
> BAQ based reports that were working perfectly in Vantage 8, and in our Epicor 9 test systems, now fail. The reason they fail is that the XML they produce is zero bytes in size, the XML file is totaly empty, it doesn't even have an XML tags in it.
> So far we're totaly stumped as to why this is happening, and Epicor also appear to eb as well.
> The BAQ works perfectly and when tested shows the required data, however, if you then create a BAQ Report and generate sample data (or generate data only via a menu item for it) the XML file that's generated for the Crytal Report is zero bytes in size.
> Thanks.
