Brian,
I always bring my grouping/sorts back to text-type.
This is your current formula:
if left({BAQReportParameter.SortBy},4)="Vend" then
{BAQReportResult.Vendor.VendorID} else
{BAQReportResult.APInvHed.InvoiceDate}
This is what I would make it:
then {BAQReportResult.Vendor.VendorID}
else ToText({BAQReportResult.APInvHed.InvoiceDate},"yyyyMMdd")
This would make the date field InvoiceDate to a text result.
So: APInvHed.InvoiceDate = 08/10/2008
ToText it with my format above and you'll result in: "20080810"
I find it's necessary to keep leading zeros and put the full year first
in the string.
Vic Drecchio
ERP Administrator
TIMCO Aviation Services
Greensboro, NC
Email: vic.drecchio@...
Office: 336.668.4410 x3091
Mobile: 704.530.3092
Of Brian Stenglein
Sent: Wednesday, October 29, 2008 2:05 PM
Subject: [Vantage] Re: BAQ Report Question - Sorting by User Selection
Thanks for the advice Vic. Using the Grouping Options to create the
sort does provide more options than just using the straight sort, good
idea. Looking at the Employee Efficiency report was also useful, I
found I was really trying to do the same thing that they did in creating
the group formula field but I was trying to use it for the sort. I'm
still having one problem with the formula however.
The fields my sort options are choosing from are 2 different data types.
I have a Vendor ID and an Invoice Date.
This is my formula:
when I try to save it, I get "A string is required here" where the date
is.
If I change the date to a string using the CSTR() function the error
goes away but of course the dates don't sort properly. Is there a way
to mix data types in the formula field to handle this?
One other question. Does anybody know if using the "Startswith"
operator is better, worse, or the same as using the "left" function as I
did above?
Brian Stenglein
--- In vantage@yahoogroups.com, "Vic Drecchio" <vic.drecchio@...>
wrote:
in the string.
Vic Drecchio
ERP Administrator
Greensboro, NC
Of Brian Stenglein
This is my formula:
is.
did above?
Brian Stenglein
wrote:
>It's a
> Sometimes it's easier to learn via reverse-engineering, as I do.
> I'd suggest looking at the standard Employee Efficiency Report.
> true BAQ Report --> Crystal. It uses Sorts for grouping.Look
> Open a copy the EmplEff.rpt found in your Vantage reports folder.
> at the formulas "Group1" and "Group2". Look at the way they'reused in
> the Group Expert (Report-->Group Expert). Instead of groupingon "real"
> static fields, they group on formulas with dynamic results. It'sone of
> the coolest features of Crystal.BAQReportParameter
> Crystal is amazingly flexible with it's conditional formatting and
> suppressions. Use these literal values passed in the
> table to do some creative, fun reporting.these
> In fact, even though its primary purpose is "sorting", I've used
> fields for many other purposes, too, such a toggling between reportgenerated
> formats (summary vs. detail).
> Run the Employee Efficiency report from Vantage. Get the XML
> and play with it locally with a copy of the EmplEff.rpt.Behalf
> Let me know if you have more questions. Good luck.
> Vic Drecchio
> ERP Administrator
> Greensboro, NC
> Of Brian Stengleinclass
> Sent: Tuesday, October 28, 2008 5:05 PM
> Subject: [Vantage] BAQ Report Question - Sorting by User Selection
> I'm just learning all of the new things in 8.X and I took a 4 hour
> at Perspectives about BAQ Reports. We learned how to design theform
> and allow users to choose how they want to sort their data.all
> We learned how to connect the data to a Crystal Report. That was
> pretty easy. What they failed to teach us is how to get the reportto
> sort using the selections chosen by the user on the form, whichhappens
> to be the missing link for using this reporting method.the
> I see that the data for the choices made by the user are passed to
> report in the table BAQReportParameter in the SortBy and SortFieldsSort
> fields. The data in the Sort by field is the description of the
> Option like "Vendor\Date". The data in the SortFields contains thesuch
> direction of the sort A or D with some extra seperator characters
> as .`A~.`A~ I don't see how to programmatically change the wayCrystal
> sorts using this kind of data.is
> My question is, how do I use those to make Crystal do what the user
> requesting? Is it even possible?must
> Thanks,
> Brian Stenglein
> Clow Stamping Co.
> have already linked your email address to a yahoo id to enableaccess. )
> (1) To access the Files Section of our Yahoo!Group for ReportBuilder
> and Crystal Reports and other 'goodies', please goto:------------------------------------
