I have a BAQ report that was setup using an RDD due to needing multiple BAQs. There are two parameters which are in all the BAQs and in the RDD Report Criteria - Job Num and Assembly Seq. Assembly Seq is an Int format. BAQ parameter and RDD Criteria Mapping are setup to “Skip if Empty” so that the user can enter a Job Number and leave the Assembly Seq blank which should pull all assemblies for the job.
This works great on the Classic Report Menu
However, the Kinetic Report Menu is auto populating this parameter with a 0 and even if I remove the 0 when the report runs it only pulls the Assembly 0. Has anyone experienced this? Any idea how to get this to work in Kinetic?
Including screen shots of the RDD that has been working great for the past 3 years in Classic.
