Hello everyone,
I have encountered a very unusual issue in Epicor Kinetic, and I hope someone has resolved it before.
When creating a dashboard using the application wizard in Epicor Kinetic versions 2024.1 and 2024.2, if you set up two grids powered by the same BAQ, the application wizard will link the two grids together.
For example, if you expand Grid 1, it will populate both Grid 1 and Grid 2; similarly, if you expand Grid 2, it will populate both Grid 2 and Grid 1 at the same time.
The strange part is that both grids have no connection to each other, aside from referencing the same BAQ in the provider model. They have completely different data views set in the Provider model’s epBinding. Yet, when you expand either grid, the Kinetic UI populates both dataviews.
