BAQ Summary tables and Calculated fields - syntax
Gregg,
I wanted to Thank you for your help.
I did use the 3 Data Directives you sent in your email. Instead of firing
a BPM, I used the DMT to set the initial values.
I heard people were doing mass update via BPM but, did not know how.
Thanks for the tip on the UD table.
Your help has made reporting Excess Inventory much easier.
Thanks much!!
Cathy
Greg Payne
Sent: Wednesday, June 12, 2013 6:31 PM
Subject: RE: [Vantage] BAQ Summary tables and Calculated fields - syntax
I use Ud03 for triggering any mass update bpm. A consultant I used made a
utilities submenu back when I first started in Epicor and put a menu item
for UD maintenance. entering any info in the table and saving will trigger
the Update method to run.
make a menu item and in the program put Epicor.Mfg.UI.UD03Entry.dll. clink
new and then enter any data and update to run the utility.
Greg
Behalf Of Cathy
Sent: Wednesday, June 12, 2013 7:36 PM
Thank you so much -
On the "Initialize PartWhse on UD03 update" What is in UD03?
Cathy
<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com
<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>] On
Behalf Of
Greg Payne
Sent: Wednesday, June 12, 2013 4:28 PM
here you go. I also set the extended properties on the fields, so they come
into baqs with the correct labels and not generically numberxx or datexx.
HTH
Greg Payne
DD on PartDtl
/* Update Number01 with OnOrder */
define variable OnOrder as decimal no-undo initial 0.
For First ttPartDtl where ttPartDtl.SourceFile = 'PO'.
For First PartWhse where PartWhse.Company = cur-comp and PartWhse.PartNum =
ttPartDtl.partnum.
For Each PartDtl where PartDtl.Company = PartWhse.Company and
PartDtl.Partnum = PartWhse.PartNum and PartDtl.SourceFile = 'PO'.
Message " DEBUG - PartNum " + PartDtl.PartNum + " Quantity " +
string(PartDtl.Quantity).
OnOrder = OnOrder + PartDtl.Quantity.
End. /* end PartDtl */
Assign PartWhse.Number01 = OnOrder.
End. /* End PartWhse */
End. /* End ttPartDtl */
For each ttUD03 where (ttUD03.rowmod = 'A' or ttUD03.rowmod = 'U') and
ttUD03.Company = cur-comp.
For Each PartWhse where PartWhse.Company = cur-comp.
Assign OnOrder = 0.
End.
DD on PartTran for last Receipt Date
/* Assign LastRecv Date */
message "DEBUG - In part Tran " .
For Each ttPartTran where ttpartTran.Company = cur-comp and
(ttPartTran.TranType = "PUR-STK" or ttPartTran.TranType = "PUR-MTL" or
ttPartTran.TranType = "INS-STK" or (ttPartTran.TranType = "STK-STK" and
ttpartTran.WareHouse2 = "RIHOLD")),
First PartWhse fields ( Date01 ) where ttPartTran.Company = PartWhse.Company
and ttPartTran.Partnum = PartWhse.PartNum and ttPartTran.WareHouseCode =
PartWhse.WareHouseCode and ttPartTran.TranDate > PartWhse.Date01
exclusive-lock.
Message " DEBUG - Assign Date to Part " ttPartTran.PartNum + " " +
string(partWhse.Date01) + ' ' + ttpartTran.Rowmod + " type " +
ttPartTran.TranType.
Assign PartWhse.Date01 = ttPartTran.TranDate.
End.
DD on PartTran for last Issue Date
/* Assign LastIssued Date */
ttPartTran.TranType = "STK-MTL",
First PartWhse fields ( Date02 ) where ttPartTran.Company = PartWhse.Company
PartWhse.WareHouseCode and ttPartTran.TranDate > PartWhse.Date02
exclusive-lock.
string(partWhse.Date02) + ' ' + ttpartTran.Rowmod + " type " +
Assign PartWhse.Date02 = ttPartTran.TranDate.
End.
<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> ] On
Behalf Of Cathy
Sent: Wednesday, June 12, 2013 6:29 PM
Thank you Greg,
The DD and the update BPM would be appreciated.
Cathy
Behalf Of
Greg Payne
Sent: Wednesday, June 12, 2013 2:35 PM
Getting excess is a pain. I had the same issue with PartDtl, so I did a data
directive on PartDtl to build On Order(supply) in PartWhse. I also update
PartWhse with last purchased and last issued date, so we can decide when to
write off the excess. This makes the CR easier to deal with.
Let me know if you want the DD and I have an update bpm on a UD to set the
initial values.
Greg
Behalf Of Cathy
Sent: Wednesday, June 12, 2013 4:31 PM
I started with summarizing PartWhse the Quantity on Hand.
In the Crystal report I created a formula for the total of Demand and Supply
from the partdtl table.
However, I am doing an excess Inventory report where I take the (Qty on Hand
+ Supply) - (total Demand - minimum on Hand) * Avg Cost = Excess$
Each part is a single line so the detail is depress.
I could not sort of Excess$ because it is calculated at the group level.
So I thought I would summarize the partdtl table.
I would like to total by sourcefile by supply and demand.
If there a way to TOTAL a summarized table with an IF statement?
Behalf Of
Dan Godfrey
Sent: Wednesday, June 12, 2013 1:13 PM
Just to back up, why are you wanting to TOTAL PartDtl instead of
PartWhse.OnHandQty?
Dan Godfrey
(805) 389-1935 x 251
Behalf Of cathyattechnologicsys
Sent: Wednesday, June 12, 2013 11:29 AM
Subject: [Vantage] BAQ Summary tables and Calculated fields - syntax
I found that in a BAQ you can only have 1 summary table.
We have a progress DB so this is my only choice.
What I want to do is total demand and total supply.
The PartWhse table has total demand but, it does not have total supply.
I want to total the PartDtl I want to total the records where the sourcefile
is PO or JH.
What I have so far is:
IF PartDtl.SourceFile = 'JM' OR PartDtl.SourceFile = 'OR' then
TOTAL(PartDtl.Quantity)
Else 0
It is not working. What is the correct syntax?
Is there a syntax for IN - example PartDtl.SourceFile IN ('JM', 'OR') ?
Thank you
CONFIDENTIALITY NOTICE: The data attached/enclosed may contain information
(including technology and technical data) which is subject to the U.S.
International Traffic in Arms Regulations (ITAR) or Export Administration
Regulations (EAR). This information may not be exported, released, or
disclosed to foreign persons either inside or outside the United States
without first obtaining the proper U.S. export license or written
authorization. In addition, the information and articles described herein
are either patented or proprietary, and the copying or reproduction thereof
is prohibited without ADVANCED Motion Controls prior written consent. If you
are not the intended recipient (or have received this e-mail in error),
please notify the sender immediately and destroy this e-mail. Any
unauthorized copying, disclosure or distribution of the material in this
e-mail is strictly forbidden. Thank you for your compliance.
The information contained in this communication, including attachments, is
privileged and confidential. It is intended only for the exclusive use of
the addressee. If the reader of this message is not the intended recipient,
or the employee or agent responsible for delivering it to the intended
recipient, you are hereby notified that any dissemination, distribution or
copying of this communication is strictly prohibited. If you have received
this communication in error, please notify us at 727-578-6280 and
immediately delete the communication.
"This (document/presentation) may contain technical data as defined in the
International Traffic In Arms Regulations (ITAR) 22 CFR 120.10. Export of
this material is restricted by the Arms Export Control Act (22 U.S.C. 2751
et seq.) and may not be exported to foreign persons without prior approval
form the U.S. Department of State."
I want to total the PartDtl I want to total the records where the sourcefile is PO or JH.
Else 0
Thank you
Just to back up, why are you wanting to TOTAL PartDtl instead of PartWhse.OnHandQty?
Dan Godfrey
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of cathyattechnologicsys
Else 0
Thank you
CONFIDENTIALITY NOTICE: The data attached/enclosed may contain information (including technology and technical data) which is subject to the U.S. International Traffic in Arms Regulations (ITAR) or Export Administration Regulations (EAR). This information may not be exported, released, or disclosed to foreign persons either inside or outside the United States without first obtaining the proper U.S. export license or written authorization. In addition, the information and articles described herein are either patented or proprietary, and the copying or reproduction thereof is prohibited without ADVANCED Motion Controls prior written consent. If you are not the intended recipient (or have received this e-mail in error), please notify the sender immediately and destroy this e-mail. Any unauthorized copying, disclosure or distribution of the material in this e-mail is strictly forbidden. Thank you for your compliance.
Dan Godfrey
PartWhse.OnHandQty?
Dan Godfrey
is PO or JH.
Else 0
Thank you
Getting excess is a pain. I had the same issue with PartDtl, so I did a data directive on PartDtl to build On Order(supply) in PartWhse. I also update PartWhse with last purchased and last issued date, so we can decide when to write off the excess. This makes the CR easier to deal with.
Let me know if you want the DD and I have an update bpm on a UD to set the initial values.
Greg
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Cathy
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of
Dan Godfrey
PartWhse.OnHandQty?
Dan Godfrey
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
[mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> ] On
To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
is PO or JH.
Else 0
Thank you
The information contained in this communication, including attachments, is privileged and confidential. It is intended only for the exclusive use of the addressee. If the reader of this message is not the intended recipient, or the employee or agent responsible for delivering it to the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please notify us at 727-578-6280 and immediately delete the communication.
Thank you Greg,
Cathy
Greg Payne
initial values.
Greg
Behalf Of Cathy
Behalf Of
Dan Godfrey
PartWhse.OnHandQty?
Dan Godfrey
is PO or JH.
Else 0
Thank you
here you go. I also set the extended properties on the fields, so they come into baqs with the correct labels and not generically numberxx or datexx.
HTH
Greg Payne
DD on PartDtl
For First PartWhse where PartWhse.Company = cur-comp and PartWhse.PartNum = ttPartDtl.partnum.
For Each PartDtl where PartDtl.Company = PartWhse.Company and PartDtl.Partnum = PartWhse.PartNum and PartDtl.SourceFile = 'PO'.
Message " DEBUG - PartNum " + PartDtl.PartNum + " Quantity " + string(PartDtl.Quantity).
For each ttUD03 where (ttUD03.rowmod = 'A' or ttUD03.rowmod = 'U') and ttUD03.Company = cur-comp.
Assign OnOrder = 0.
End.
For Each ttPartTran where ttpartTran.Company = cur-comp and (ttPartTran.TranType = "PUR-STK" or ttPartTran.TranType = "PUR-MTL" or ttPartTran.TranType = "INS-STK" or (ttPartTran.TranType = "STK-STK" and ttpartTran.WareHouse2 = "RIHOLD")),
First PartWhse fields ( Date01 ) where ttPartTran.Company = PartWhse.Company and ttPartTran.Partnum = PartWhse.PartNum and ttPartTran.WareHouseCode = PartWhse.WareHouseCode and ttPartTran.TranDate > PartWhse.Date01 exclusive-lock.
Message " DEBUG - Assign Date to Part " ttPartTran.PartNum + " " + string(partWhse.Date01) + ' ' + ttpartTran.Rowmod + " type " + ttPartTran.TranType.
End.
For Each ttPartTran where ttpartTran.Company = cur-comp and ttPartTran.TranType = "STK-MTL",
First PartWhse fields ( Date02 ) where ttPartTran.Company = PartWhse.Company and ttPartTran.Partnum = PartWhse.PartNum and ttPartTran.WareHouseCode = PartWhse.WareHouseCode and ttPartTran.TranDate > PartWhse.Date02 exclusive-lock.
Message " DEBUG - Assign Date to Part " ttPartTran.PartNum + " " + string(partWhse.Date02) + ' ' + ttpartTran.Rowmod + " type " + ttPartTran.TranType.
End.
Thank you Greg,
Cathy
Greg Payne
initial values.
Greg
Behalf Of Cathy
Behalf Of
Dan Godfrey
PartWhse.OnHandQty?
Dan Godfrey
is PO or JH.
Else 0
Thank you
Thank you so much -
Cathy
Greg Payne
HTH
Greg Payne
DD on PartDtl
ttPartDtl.partnum.
Assign OnOrder = 0.
End.
exclusive-lock.
End.
exclusive-lock.
End.
Behalf Of Cathy
Thank you Greg,
Cathy
Behalf Of
Greg Payne
initial values.
Greg
Behalf Of Cathy
Behalf Of
Dan Godfrey
PartWhse.OnHandQty?
Dan Godfrey
is PO or JH.
Else 0
Thank you
Hi Greg,
Would you mind posting the DD and update BPM to the files section of this usergroup as I would like to see your code as well?
Cheers..
J Seeman
> Greg
> Dan Godfrey
> PartWhse.OnHandQty?
> Dan Godfrey
> is PO or JH.
> Else 0
> Thank you
I use Ud03 for triggering any mass update bpm. A consultant I used made a utilities submenu back when I first started in Epicor and put a menu item for UD maintenance. entering any info in the table and saving will trigger the Update method to run.
make a menu item and in the program put Epicor.Mfg.UI.UD03Entry.dll. clink new and then enter any data and update to run the utility.
Greg
Thank you so much -
Cathy
Greg Payne
HTH
Greg Payne
DD on PartDtl
ttPartDtl.partnum.
Assign OnOrder = 0.
End.
exclusive-lock.
End.
exclusive-lock.
End.
Behalf Of Cathy
Thank you Greg,
Cathy
Behalf Of
Greg Payne
initial values.
Greg
Behalf Of Cathy
Behalf Of
Dan Godfrey
PartWhse.OnHandQty?
Dan Godfrey
is PO or JH.
Else 0
Thank you
All of the code is in the 7:28 PM EDT Email. We are at 85 of 100 MB of storage in the file section, so I won't post it there.
If you need the exported bpm files I will send them direct.
Greg
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of jseeman21
Sent: Wednesday, June 12, 2013 7:49 PM
Subject: [Vantage] Re: BAQ Summary tables and Calculated fields - syntax
Hi Greg,
Cheers..
J Seeman
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, Greg Payne <gpayne@...<mailto:gpayne@...>> wrote:
> Greg
> From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of Cathy
> From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>] On Behalf Of
> Dan Godfrey
> To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>
> PartWhse.OnHandQty?
> Dan Godfrey
> From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> ] On
> To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
> is PO or JH.
> Else 0
> Thank you
