BAQ to Service Connect Link
We’ve setup a Service Connect workflow from a BAQ and linked them together. When we update from the BAQ, it says no errors, but nothing updates. When I check the Service Connect Admin Console, I can’t find any log.
do you have document tracking turned on in your workflow?
Yes
We were getting errors on the BAQ side when it wasn’t setup quite right. Once we fixed the workflow, it said complete without errors, but nothing changes.
those are hell to step thru…getting some screen shots of your setup might help. Did you create the basic workflow itself from within the BPM editor inside the BAQ? That’s crucial to getting the input/output schemas right.
Attached is a backup of the workflow. Would you be willing to just take a quick glance and see if something jumps out at you?UD07_Update.scs (1.1 MB)
Austin,
For curiosity, what version are you using?
10.1.400.23
