# BAQ UI & BAQSvc REST API Limitations
**URL:** <https://www.epiusers.help/t/baq-ui-baqsvc-rest-api-limitations/107024>\
**Category:** Kinetic ERP\
**Tags:** baq-reports, baq, customization, rest, rest-api\
**Created:** [September 15, 2023, 10:16am UTC](https://www.epiusers.help/t/baq-ui-baqsvc-rest-api-limitations/107024 "2023-09-15T10:16:28Z")\
**Posts on this page:** 1\
**Showing post:** 7
<div class="post-metadata">
**Author:** ![klincecum](https://www.epiusers.help/user_avatar/www.epiusers.help/klincecum/32/100137_2.png) [@klincecum](https://www.epiusers.help/u/klincecum)\
**Post date:** [September 15, 2023, 2:47pm UTC](https://www.epiusers.help/t/baq-ui-baqsvc-rest-api-limitations/107024/7 "2023-09-15T14:47:08Z")
</div>
This is the post I was referring to:
> [@REST API for JobEntrySvc/JobEntries only returns 100 results](https://www.epiusers.help/t/rest-api-for-jobentrysvc-jobentries-only-returns-100-results/54756/7):
> To change/remove the limit use \<add key="DefaultMaxRowCount" value="\<number or 0 to remove the limit\>" /\> into web.config section.
_[View the full topic](https://www.epiusers.help/t/baq-ui-baqsvc-rest-api-limitations/107024)._
