Hi all,
I’ve been struggling with this dashboard.
Updateable Dashboard to modify Employee labor rate. UPDBaq working, UPDDashboard working.
Issue?
Dashboard tracker view customized to show a BAQCombo dropdown field. After selecting the desiered employee, the intention is to trigger the “refresh” action in dashboard, so far I need to manually click the refresh tool at the top and it works.
I have created some events with the event wizard. but nothing seems to be working… i mean… I can’t even test because of some script errors.
This is my Dashboard (very simple one)
here is the code inside of my Customized Tracker View:
// Custom code for 96855c5d-b778-48fd-a7b4-4d0f2b252e55
// Created: 10/26/2023 8:17:25 AM
using System;
using System.ComponentModel;
using System.Data;
using System.Diagnostics;
using System.Windows.Forms;
using Ice.BO;
using Ice.UI;
using Ice.Lib;
using Ice.Adapters;
using Ice.Lib.Customization;
using Ice.Lib.ExtendedProps;
using Ice.Lib.Framework;
using Ice.Lib.Searches;
using Ice.UI.FormFunctions;
using Infragistics.Shared;
using Infragistics.Win;
using Infragistics.Win.UltraWinGrid;
using System.Reflection;
public static class Script
public static void InitializeCustomCode()
Script.SelEmp.ValueChanged += new System.EventHandler(Script.SelEmp_ValueChanged);
Script.f5.CheckedValueChanged += new System.EventHandler(Script.f5_CheckedValueChanged);
public static void DestroyCustomCode()
Script.SelEmp.ValueChanged -= new System.EventHandler(Script.SelEmp_ValueChanged);
Script.f5.CheckedValueChanged -= new System.EventHandler(Script.f5_CheckedValueChanged);
// Begin Custom Code Disposal
// End Custom Code Disposal
private static void SelEmp_ValueChanged(object sender, System.EventArgs args)
f5.Checked = true;
private static void f5_CheckedValueChanged(object sender, System.EventArgs args)
MainController.AppControlPanel.HandleToolClick("RefreshTool", new
Infragistics.Win.UltraWinToolbars.ToolClickEventArgs(MainController.MainToolManager.Tools["RefreshTool"], null));
and this are the erros I’m getting:
any help or suggestion will be very appreciated…
