Bar Codes in Part Maintenance
Hi,
Thanks for ur kind support, Could you please advice on how to change the font to "Dataworks Bar 39". Since in Datadictionary viewer, the font field for partmaintenance in RcvLabel.Rpt is not active, and also if i change in sql db, then everything will be changed. But i need to review for bar code item only. It means everytime i need to change in SQL DB for that tabel.
Regards,
Deepa.M
----- Original Message ----
Sent: Thursday, April 3, 2008 8:08:26 PM
Subject: [Vantage] RE: Bar Codes in Part Maintenance
You shouldn't need to do a bar code in part maintenance since you
don't scan the screen. You would do a bar code on the print out by
customizing a Crystal Report using the Part Number (?) changing the
font to "DataWorks Bar 39". Look at the RcvLabel.rpt as an example.
--- In vantage@yahoogroups .com, deep luv <deepait_10@ ...> wrote:
> Hi,
> In Vantage 8.03.404, how to create a bar code item in Part maintenance?
> Regards,
> M.Deepa
____________ _________ _________ _________ _________ _________ _
> You rock. That's why Blockbuster' s offering you one month of
Blockbuster Total Access, No Cost.
> http://tc.deals yahoo.com/ tc/blockbuster/ text5.com
____________________________________________________________________________________
You rock. That's why Blockbuster's offering you one month of Blockbuster Total Access, No Cost.
http://tc.deals.yahoo.com/tc/blockbuster/text5.com
Hi,
Regards,
M.Deepa
--- In vantage@yahoogroups.com, deep luv <deepait_10@...> wrote:
> Hi,
> Regards,
> M.Deepa
What are you tring to print? Most of the reports have a bar code print
option. If you are using scan guns rather than the scanner pen you will
have to modify some of the reports to make them human readable which
means you have to put an "*" in front and in back of the field to be
printed
Kersten MacLennan
IT/ERP Analyst
Semrock, Inc.
3625 Buffalo Rd.,
Suite 6
Rochester, NY 14624
585-594-7009
585-594-7095 fax
kmaclennan@...
The Standard in Optical Filters for Biotech & Analytical Instrumentation
Hundreds of Thousands of Ion Beam Sputtered filters delivered -
extensive inventory now!
The information contained in this message and any attachments may be
privileged, confidential, and protected from disclosure. If the reader
of this message is not the intended recipient, or any agent responsible
for delivering this message to the intended recipient, you are hereby
notified that any dissemination, distribution, or copying of this
communication may be unlawful and therefore strictly prohibited. If you
received this message in error, please reply to the message and delete
it. Thank you
Of saab_barracuda
Sent: Thursday, April 03, 2008 12:08 PM
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , deep
> Hi,
maintenance?
> Regards,
> M.Deepa
<http://tc.deals.yahoo.com/tc/blockbuster/text5.com>
