You change the font in your Crystal report.
I believe the tick box for use barcodes is picked up in crystal so crystal then
knows whether to print the barcode or not.
Sent: Mon, 6 June, 2011 17:57:49
Subject: Re: [Vantage] Re: Bar Codes
Â
ok, so i will check out id automation for the font, but again, how do i tell
Epicor 9 to use that font instead of the 3of9 that epicor defaults to?
On Mon, 06 Jun 2011 16:33:33 -0000
"cooner_55421" <cooner_55421@...> wrote:
I use IDAutomation for 128
Â
>3 of 9Supplied by Epicor
>128 will work better.Customer purchase
--- In vantage@yahoogroups.com, "Nick" <nick@...> wrote:
> Along this subject,
> Is there any way to change the default font for the
>barcodes? we think that
> 3 of 9 wont work for us, but 128 will work better. i see
>there is just a
> check box that says "print barcodes". but how do i tell
>it which one to
> default to?
> On Mon, 06 Jun 2011 13:45:51 -0000
> "Sean Toler" <seantoler@...> wrote:
> I think I do.
> Vic, your formula worked like magic! Thanks!
> --- In vantage@yahoogroups.com, Chris Thompson
> <chriselectrix@> wrote:
> > Sorry the time zone difference meant I couldnt get back
> >in time.
> > Hope you have it sorted now.
> > From: Vic Drecchio <vic.drecchio@>
> > Sent: Fri, 3 June, 2011 20:24:15
> > Subject: RE: [Vantage] Bar Codes
> > Â
> > Sean, in your formula use the "ToText" function and you
> >can suppress the
> > comma.
> > Syntax: ToText({ShipHed.PackNum},0,"")
> > The Zero says to have no decimal places. The empty
>quotes
> >tell it to
> > use "nothing" as the thousands separator.
> > So, you barcoded formula might look like this:
> > "*" + ToText({ShipHed.PackNum},0,"") + "*"
> > Vic
> > From: vantage@yahoogroups.com
> >[mailto:vantage@yahoogroups.com] On Behalf
> > Of Sean Toler
> > Sent: Friday, June 03, 2011 12:18 PM
> > Subject: [Vantage] Bar Codes
> > Chris,
> > Thank you for all of your help with the bar codes
>thread.
> >We spoke with
> > our customer and they've agreed to allow us to use Code
> >39 which will
> > save us from having to purchase a code 128 font.
> > I have started working on our packing slip and am
>having
> >some success
> > but I have come across a slight snag that I was
>wondering
> >if you could
> > help me with. The packing list number, when it comes
>into
> >the Crystal
> > Report from Vantage comes in in this format: 20,509.00.
> >This can be
> > easily modified in Crystal when it is seen as a number
>so
> >that it
> > appears as 20509. But, once I use it in a formula and
> >convert it to
> > text, I can't seem to modify it so that it looks
>correct,
> >thus, the bar
> > code reads 20 509.00. Do you know how this could be
> >corrected?
> > Sean
