Barcodes/RB/Fonts
Thanks Greg... Les
> -----Original Message-----
> From: Greg Krumrey [SMTP:gkrumrey@...]
> Sent: Tuesday, August 20, 2002 10:03 AM
> To: 'vantage@yahoogroups.com'
> Subject: RE: [Vantage] Barcodes/RB/Fonts
> This formula creates a string, that when printed in DataWorks Bar 39
> yields
> one barcode that outputs Job Number, Assembly & Operation in one scan. The
> "*" are required at both ends (start/stop codes) and the $I decode into
> tab
> characters.
> "*" + JobOper.JobNum + "$I" + String(JobOper.AssemblySeq,">>9") + "$I" +
> String(JobOper.OprSeq,">9999") + "$I*"
> Here's a parameter passed to the report & output with a tab. If you want
> Carriage Return (CR), use $M.
> "*" + RUNTIME-PARAMETER("JobNum") + "$I*"
> The $I and $M codes need to be present in the barcode font (they are in
> DataWorks Bar 39) and the reader you are using must have this setting
> turned
> on. On mine, it's called Full Ascii Code 39.
> Hope this helps!
> Greg Krumrey, Information Manager, Patriot Machine, Inc.
> Voice: 636-940-1776 x 130, fax: 636-940-8933
> email: mailto:greg.krumrey@...
> Alt: mailto:greg@... Web: www.patriot-machine.com
> From: Les Tingley [mailto:ltingley@...]
> Sent: Tuesday, August 20, 2002 7:48 AM
> To: vantage@yahoogroups.com
> Could somebody please send me a sample RB label in code 39? I'd like to
> see
> how you are handling the need for * or !.
> Thanks,
> Les Tingley
> MIS
> Decorated Products
> > From: Wayne Cox [SMTP:wmc20@...]
> > Sent: Tuesday, August 20, 2002 8:37 AM
> > At 08:21 AM 8/20/2002 -0400, you wrote:
> > >What's up with the postage stamp looking thing on our UPS sticker? It
> > >supposedly holds "way more" info than the normal looking straight
> lines.
> > It's a 2 dimensional bar code (guess "bar code" is really a misnomer -
> > it's
> > dots!) I don't know a whole lot of detail on them, but that might get
> you
> > Googling in the right direction. Yes, they have a much higher data
> > density
> > and capacity than the old 1-D stripes. I've been told newer label
> > printers, like Zebra, have firmware built in or available as an add-on
> to
> > take care of the formatting.
> > Got more curious myself - here's a good 101:
> > http://www.adams1.com/pub/russadam/stack.html
> > -Wayne
> > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> > have already linked your email address to a yahoo id to enable access. )
> > (1) To access the Files Section of our Yahoo!Group for Report Builder
> and
> > Crystal Reports and other 'goodies', please goto:
> > http://groups.yahoo.com/group/vantage/files/.
> > http://groups.yahoo.com/group/vantage/messages
> > (3) To view links to Vendors that provide Vantage services goto:
> > http://groups.yahoo.com/group/vantage/links
> > Your use of Yahoo! Groups is subject to
> http://docs.yahoo.com/info/terms/
> have
> (1) To access the Files Section of our Yahoo!Group for Report Builder and
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
For those using Report Builder for Barcodes, what and where are you
getting all the correct fonts? I would need fonts for all the popular
codes.
Les Tingley
MIS
Decorated Products
http://www.bizfonts.com/ I aquired this link in my research. I don't know
all thier resources. At the moment our need is only code 3 of 9 (Not to
be confused with 7 of 9 our friendly neighborhood borg)
Shirley
Sent: Tuesday, August 20, 2002 8:03 AM
Subject: [Vantage] Barcodes/RB/Fonts
codes.
Les Tingley
MIS
Decorated Products
Yahoo! Groups Sponsor
ADVERTISEMENT
To anyone that is a bar code guru:
supposedly holds "way more" info than the normal looking straight lines.
Is this something that may or could end up being used?
Would one of those "squares" of data accomodate an entire pack list, job
traveler, etc?
Just curious before I redesign some forms to fit in the regular type bar
codes.
TIA!
Rick Gors
codes.
Les Tingley
MIS
Decorated Products
ADVERTISEMENT
It's a 2 dimensional bar code (guess "bar code" is really a misnomer - it's
dots!) I don't know a whole lot of detail on them, but that might get you
Googling in the right direction. Yes, they have a much higher data density
printers, like Zebra, have firmware built in or available as an add-on to
-Wayne
Could somebody please send me a sample RB label in code 39? I'd like to see
Les Tingley
MIS
Decorated Products
> it's
> density
> -Wayne
This formula creates a string, that when printed in DataWorks Bar 39 yields
"*" are required at both ends (start/stop codes) and the $I decode into tab
characters.
DataWorks Bar 39) and the reader you are using must have this setting turned
Hope this helps!
Les Tingley
MIS
Decorated Products
> it's
> density
> -Wayne
Wayne ... that link is WAY to much fun ... !!!
In fact, I think it's a keeper for all of us to have on hand next time
management thinks that Bar-Coding is a great and EASY idea.
We had a customer that wanted us to bar code their steel bars for them (
greasy, oily, scaly, etc ). When nothing would stick they asked us to just
stick the bar code labels on the pallets or banding. When those fell of
due to - dust, water, 60 mile/hr wind on the back of the truck etc, they
asked us to use shrink wrap around the labels. Of course, their receiving
people couldn't "Read" the labels through the shrink wrap so they have to
cut open the shrink wrap to get to the labels. I doubt either company
saved any money in the process. But heck, it was a great idea ...
Then you have the AIAG labels that we used for a number of companies. It's
a pretty decent "Standard" ... that is, if our customers would remember that
it is supposed to be a "Standard" and quite trying to improve on it. I
have a number of different formats that we use - 1 is the original standard
- the rest are only good for individual companies. Oh well ...
Thanks Wayne !
Todd
Sent: Tuesday, August 20, 2002 7:37 AM
<http://www.adams1.com/pub/russadam/stack.html>
-Wayne
ADVERTISEMENT
<http://rd.yahoo.com/M=228862.2128520.3581629.1829184/D=egroupweb/S=17050071
83:HM/A=1182693/R=0/*http://adfarm.mediaplex.com/ad/ck/990-1736-1039-335>
