Make sure there is white space (blank area) before and after the barcode. Sometimes the margin is different when printing from Vantage than from Crystal. This problem is worse when printing to labels. If it is printing too close to the edge then it may not have enough blank space before the barcode or even worse be missing the 1st bar or two.Â
I have seen this printing on different printers.
Â
Sent: Tuesday, May 24, 2011 2:39 PM
Subject: [Vantage] Barcodes that won't scan from Vantage
Â
Hello everyone,
I'm ready to deploy some labels into Vantage, but for some reason, the Barcodes will not scan when the label is printed out of Vantage.
The barcodes scan fine out of Crystal. The barcode font is installed on both the server and the client.
The wierd thing is that I have other forms and labels with barcodes where the codes DO scan out of Vantage.
This is very perplexing. Any help would be appreciated.
Thank you,
Leslie Martin
Allwire Inc.
Â
Â
Hello everyone,
Thank you,
Leslie Martin
Allwire Inc.
