Have you enabled Full ASCII on the scanner? the fact that your notepad
example does the Tab says you probably do, but just checking.
Some scanners need to be configured first.
Another thing to consider is using the + not the & in your Crystal
Report formula.
My job travelers have this as the formula of a calculated field on a
router:
"*" + {JobAsmbl.JobNum} + "$I*"
Lastly, you may need to cast that calcrunqty as a char, like
cstr(@CalcRunQty)
Hope any of this helps you,
Tony
Report formula.
router:
cstr(@CalcRunQty)
Tony
--- In vantage@yahoogroups.com, "S. Michael Reeves" <mreeves@...> wrote:
> Doesn't work unfortunately.
> Maybe it's my scanner, but I can't figure the stupid thing out. I've
> tried to configure the scanner and so far my configuring got it so it
> will tab in notepad, italicize in word and simply not display the $I
> in Vantage, (but otherwise display the CalcRunQty and that's it)...
> Maybe I'm doing something wrong with configuring the scanner? It's a a
> Handheld 3800g.
> Thanks!
> --Mike
> --- In vantage@yahoogroups.com, "Chris Crosta" <chris@> wrote:
> > Mike,
> > Not sure if you tried this but in v8.5 you needed to use double
quotes.
> > "*" & {@CalcRunQty} & "$I" & "*"
> > Chris
> > _____
> > From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On
Behalf
> > Of S. Michael Reeves
> > Sent: Tuesday, October 21, 2008 2:13 PM
> > Subject: [Vantage] Re: Barcoding...
> > What your saying makes sense but unfortunately I have to have this
> > variable in there, (thus no manual printing possible). This variable
> > will be used several times a day, (this is all in the Priority
> > Dispatch Report... I'm simply modifying it), and not only several
> > times a day but several of these barcodes, (along with others like
> > it), will be printed out. I'm mainly using this particular issue as
> > an example that I will hopefully be able to apply to the rest of the
> > reports that I slap barcodes on to.
> > Thanks for your insight! Helpful to know I'm not the only one with the
> > issue, but I am assured knowing that *someone* has a solution.
> > --Mike
> > --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ,
> > "Lynn" <lynn.khalife@> wrote:
> > > I'm not an expert, but I can share my experience with Crystal
Reports
> > > XI and barcode creation.
> > > I have 1 customer who requires spacebars to be inserted inside a
> > > concatenated barcode field. They wanted the bar code to consist of
> > > the part number then some spaces then the revision code then more
> > > spaces.
> > > The BarCode39 font available with Crystal XI is just that: it is a
> > > font. It turned out that the font is not capable of barcoding a
> > > spacebar. Instead, it simply inserts a space in the middle of the
> > > concatenated field.
> > > If your barcode fonts are not scanning, you may be experiencing the
> > > same problem. The font may not be capable of producing the Tab
> > > correctly in a bar code.
> > > To get my labels compliant for this one customer, I had to use
> > > TalBarCode ActiveX controls in a Word document. Currently I hand-
> > > type the text for each one. Fortunately, we need only 1-2 labels
per
> > > week.
> > > If a second customer requires concatenated fields like this, I will
> > > need to come up with a better solution.
> > > I will be watching these messages to see if you get some
suggestions
> > > from other users. Perhaps I will find my solution on your thread.
> > > Lynn
> > "S. Michael Reeves" <mreeves@>
> > > wrote:
> > > > Hey folks! I just want you to know that I've tried about every
> > > > possible combination of Strings for barcodes that I have found
both
> > > > here on the forums and elsewhere.
> > > > (Using Crystal Release XI and Epicor Vantage 405A
> > > > Currently, I have the following set up in a formula field:
> > > > '*' & {@CalcRunQty} & '$I' & '*'
> > > > Now, this is supposed to add a tab afterwards. Trying this sucker
> > > out
> > > > in Notepad and it works well. It tabs like it is supposed to.
> > > Trying
> > > > it in Word will change the font formatting to "Italicized"
instead
> > > of
> > > > tabbing. Okay, fine, program specific then. Scanning this thing in
> > > > the program it will be used in, Epicor, and it does nothing. It
> > > scans
> > > > and transmits the value of "@CalcRunQty" but it does not tab.
> > > > What could I be doing wrong? I'm pulling my hair out... I
figured I
> > > > had this thing solved, but then I try it and nope....
> > > > Thanks!
> > > > --Mike
