Sorry, Chris, I was just typing quickly off top of my head. You want to put it in the curly braces, like you have there.
You will have to put chr({orderhed.ordernum}) also, because ordernum is an integer.
So here's the correct string:
"*" & Chr({orderhed.ordernum}) & "$I*"
Sent: Tuesday, November 11, 2008 8:12:55 AM
Subject: Re: [Vantage] Barcoding in Vantage / Crystal
Hi Tony,
Thanks for the prompt reply.
When you say [ordernumber] do you mean {orderhed.ordernum} like that or do you actually mean to include the [square brackets]?
CHRIS
____________ _________ _________ __
To: vantage@yahoogroups .com
Sent: Tuesday, November 11, 2008 1:58:08 PM
Build the string like this:
"*" & [ordernumber] & "$I*"
but the scanner has to be programmed to be using Full 39 for this to work.
another useful one is $M which is the Enter key.
Sent: Tuesday, November 11, 2008 7:51:52 AM
Subject: [Vantage] Barcoding in Vantage / Crystal
Hi,
We are going live at the beginning of next year and I have been given the task of getting all of the forms etc designed to be used in-house.
On the Sales Order Pick List, I would like to have a barcode that contains *Order Number[TAB]* .
The asterisks are the beginning and end of the 3of9 barcode.
Order Number comes from orderhed.OrderNum.
I imagine that I need to creat a formula that reads ...
"*" & {orderhed..OrderNum } & Chr (9) & "*"
Then I would need to convert the standard Arial to the DataWorks 3of9 font.
However, when this prints, it actually puts part of the barcode, then a space then a bit more of the barcode.
The gap is obviously generated by the Chr (9) in the formula.
I have also tried an option that I read about in this yahoo group "*" & {orderhed.OrderNum} & "$I*", but the $I is just read and displayed as $I.
How can I create a barcode to display the Order Number, and to tab in one action?
Although our scanners can be configured to automatically TAB, I dont want to use this function as they are dual prupose throughout the site and some operations don't require a TAB.
Any help on this would be greatly appreciated.
Hi Tony,
CHRIS
Hi,
