Barcoding on Travelers
Thanks to all that sent the formula strings.
Got it to work!
Regards,
Chris Wineinger
ERP Specialist
Interior Systems, Inc. <http://www.isiamerica.com/>
241 N Broadway Ste 600
Milwaukee, WI 53202
Office # 414.224.0957 X2051
Direct# 414.847.0701
Cell # 414.840.6594
I'm trying to program a tab after each barcode in E9 so the field moves to the next field to scan.
I'm not sure how to add the keystroke sequence on the end of the existing barcode so it shows as one scan.
We tried to add the tab to the scanners but I couldn't get the starting field to line up when we launch the activity using a barcode, so no we're trying to do it on the traveler.
Any help with this is greatly appreciated...
Regards,
Chris Wineinger
ERP Specialist
Interior Systems Inc.
414-847-0701
Check out the docs in the Barcoding folder of the Files area of this site.
redrhyno13
Sent: Thursday, October 11, 2012 2:50 PM
Subject: [Vantage] Barcoding on Travelers
Regards,
Chris Wineinger
ERP Specialist
414-847-0701
No virus found in this message.
Checked by AVG - www.avg.com
Version: 2012.0.2221 / Virus Database: 2441/5324 - Release Date: 10/11/12
I see the code for tab but when I try to add that code to the end of the barcode in the crystal report, Crystal complains that the code is invalid. So I'm asking how that would be written in Crystal...
Chris
> redrhyno13
> Regards,
> Chris Wineinger
> ERP Specialist
> 414-847-0701
You need to ensure your scanner is configured for the extended ASCII
character set. If you have a tethered USB Symbol LS2208 scanner, also run
though the setup on the files section. If you have another scanner, consult
the manual and ensure it's set. Do some searching on this list history and
you'll see this topic covered a few times for additional examples.
redrhyno13
Sent: Thursday, October 11, 2012 3:37 PM
Subject: [Vantage] Re: Barcoding on Travelers
Chris
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , "Vic
Behalf Of
> redrhyno13
> Regards,
> Chris Wineinger
> ERP Specialist
> 414-847-0701
Depending on the model of barcode reader you are using, you may be able to program the reader itself to insert the tab after reading a barcode. We use Symbol barcode readers and the manual that comes with them describes how to program them to insert a tab or character return after reading a barcode. It's much simpler to do than programming the barcode to do it.
Sincerely,
Rory St. Lawrence
I.T. Administrator
[cid:image001.jpg@01CDA7CC.2647D060]
Labsphere, Inc.
231 Shaker Street
North Sutton, NH 03260
Phone +1 (603) 927 1061
Email rstlawrence@...<mailto:rstlawrence@...>
Mobile +1 (603) 748 4952
www.labsphere.com<http://www.labsphere.com/>
Please consider the environment before printing this email.
The information transmitted is intended only for the person or entity to
which it is addressed and may contain confidential and/or privileged
material. If you are not the addressee, any disclosure, reproduction,
copying, distribution, or other dissemination or use of this transmission in
error please notify the sender immediately and then delete this e-mail.
E-mail transmission cannot be guaranteed to be secure or error free as
information could be intercepted, corrupted, lost, destroyed, arrive late or
incomplete, or contain viruses. The sender therefore does not accept liability
for any errors or omissions in the contents of this message which arise as a result of
e-mail transmission. If verification is required please request a hard copy version.
You have to create a formula for your information and append the tab into the formula, then put the formula on the report and use the barcode font.
I was testing it on our travelers and did this:
"*"+totext({JobAsmbl.JobNum})+"$I"+trim(totext({JobAsmbl.AssemblySeq},0))+"$I"+trim(totext({JobOper.OprSeq},0))+"$I"+""+"$I"+""+"$I"+""+"$I"+""+"$I"+""+"$M"+"*"
It will enter the numbers and tab through the MES interface entering it where it needs to go.
"$I" being the tab.
> Regards,
> Chris Wineinger
> ERP Specialist
> 414-847-0701
If you are using 3 fo 9 barcodes in Crystal you need to create a formula like this ...
"*"&ToText({JobHead.JobNum})&"$I"&"*"
Sent: Thursday, 11 October 2012, 20:53
Subject: RE: [Vantage] Re: Barcoding on Travelers
Â
redrhyno13
Chris
Behalf Of
> redrhyno13
> Regards,
> Chris Wineinger
> ERP Specialist
> 414-847-0701
