Bartender Installation - Any gotchas
We are in the process of integrating Bartender into our epicor but I wanted to make sure there is no hidden problems that I may run into straight away!
Best option or someone else’s current
  • Install Bartender on the AppServer
  • Create a VM just for Bartender
  • Install bartender on the print server.
Any webinars, up to date youtube links, guides on this would be ace…
Thanks in advanced…
Aaron
It depends what version of BarTender you have, which will determine how you set it up.
BarTender Professional will require its own SQL Instance & both SQL and BT must be on the same Server. they literally restrict your SQL connection settings to have localhost
BarTender Enterprise your SQL database can be anywhere and you can install BT on a seperate Server.
We are running Enterprise (going to run)
See already one and haven’t even started!
