Is there a reason that Base TextBoxes are not available in a customization, even to get a value from ?
When I try something like
String strKeyField = txtKeyField.Text;
with txtKeyField being a Base TextBox, I get the following error when attempting to compile
Error: CS0103 - line 58 (224) - The name ‘txtKeyField’ does not exist in the current context
Are these locked up intentionally, or is this a scope issue ? I’ve no problem accessing TextBoxes I add in the customization, only the Base TextBoxes.
I’ve also tried accessing the underlying EmbeddableTextBox linked to the visible TextBox, with the same result
String strKeyField = txtKeyField_EmbeddableTextBox.Text;
Error: CS0103 - line 58 (224) - The name ‘txtKeyField_EmbeddableTextBox’ does not exist in the current context
