Batch file for new database
Hey,
Here is a sample one (assuming you're progress), ignore the parts on shutting the appsevers as you won't need it:
@REM These values are the only ones that need to be edited
@REM ======================================================
@REM Description of directories for editing
@REM --------------------------------------
@REM DLC: Should be your OpenEdge 10B directory
@REM epicordir: Should be your Epicor SystemAdmin directory
@REM dbdir: Should be your Vantage Database directory
@REM dbbkupdir: Should be your Vantage database backup directory
@set DLC=D:\epicor\oe101b
@set epicordir=D:\epicor\systemadmin
@set dbdir=E:\dbs\v803
@set dbbkupdir=E:\dbs_bkup
@REM ======================================================================
@REM Start the LIVE to PILOT copy
@REM Sets up your Windows path directory
@set PATH=%PATH%;%DLC%;%DLC%\bin
@echo =============================
@echo WARNING!!! LIVE TO PILOT COPY
@echo This will delete all data in the PILOT system
@echo and copy the LIVE database to the PILOT system.
@echo (From last nights LIVE backup)
@echo Your PILOT system will be down during this time
@echo Your LIVE system will be unaffected.
@echo If you are sure you want to do this, type "y"
@echo If you NOT wish to proceed, type "n"
@set /p yesno=Are you sure you want to do this? (y="yes",n="no"):
@if "%yesno%" NEQ "y" goto end
@echo -------------------------
@echo Shutdown PILOT appservers
call asbman -name MfgPilot80 -kill
call asbman -name MfgPilot80ProcessServer -kill
call asbman -name MfgPilot80TaskAgent -kill
@REM Pause 30 seconds
%epicordir%\winsleep 30
@echo -----------------------------------------
@echo Shutting down PILOT DB (takes 30 seconds)
call dbman -stop -database mfgpilot80
@echo ------------------------------------------------
@echo Copying LIVE to PILOT (can take about 5 minutes)
@REM call prodel %dbdir%\pilot\mfgsys
call prorest %dbdir%\pilot\mfgsys %dbbkupdir%\live\mfgsys.bak < %dbdir%\bin\yesfile.txt
call prostrct list %dbdir%\pilot\mfgsys
@echo Starting PILOT database (takes 30 seconds)
call dbman -start -database mfgpilot80
@echo Starting PILOT AppServers
call asbman -name MfgPilot80 -start
call asbman -name MfgPilot80ProcessServer -start
call asbman -name MfgPilot80TaskAgent -start
@echo Copy complete. If there are any errors please contact an administrator
@:end
@endlocal
@pause
--- In vantage@yahoogroups.com, warren klug <pirateofthemagothy@...> wrote:
> I want to run an offline Corvu reporting server and would like to upload the daily Progress backup to a reporting server that will run my daily reports. Can anyone offer suggestions for a batch file that will:
> 1. Â retrieve the nightly Vantage 6.1 backup when it completes
> 2. stop the database on the reporting server
> 3. restore the database on the reporting server
> 4. start the database on teh reporting server
> Â
> Once complete I can then launch the nightly Corvu scheduler and not interfere with all of my China users coming into the system.Â
> Â
> Thanks,
> Warren Klug
> Lion BrothersÂ
Â
Â
Warren Klug
Lion BrothersÂ
