Batch script to backup Progress database
Thanks very much ....this is really helpful :)
cheers
-Lam-
On Thu, Jan 27, 2011 at 4:35 PM, Chris Thompson <chriselectrix@...>wrote:
> Hi.
> This is an easy script. Why does it need to be manually ran? Why not
> schedule
> it?
> It take about 5-10 minutes on a 7GB DB.
> We do ours daily and back them up to an individual file - Monday's goes to
> Monday folder etc. We then have Thursday 1-4 so we can always restore to a
> month
> previous if we need to.
> This is the script for Monday's - I will explain the important lines below
> it.
> NB: I hold no responsibility if this causes any damage to your data or
> hardware
> etc. Use at your own risk. It works perfectly well for us so there is no
> reason
> why it shouldnt for you, but I would advise testing on the 'test' DB or
> server.
> @echo off
> rem Epicor BACKMFG.BAT createc:07/98 JE - editec: 11/20/02
> rem
> rem This .bat script requires modification by the system administrator
> rem to include the correct paths and dirctory locations.
> rem
> rem NOTh:
> rem Drive letter of database be a physical drive, not mapped.
> rem Drive letter of backup copy can be physical or mapped,
> rem on server or across network.
> rem
> rem General syntax of BACKMFG.BAT does the following:
> rem 1) Surpress screen display (echo off)
> rem 2) Drive letter locating the MFGBKUP.BAT file.
> rem 3) Directory path to the MFGBKUP.BAT file.
> rem 4) Call of MFGBKUP to do the backup "online"
> rem of c:\path\mfgsys.db database to c:\backupdir\backup.file.
> rem
> rem System admin should EDIT the following:
> rem a) Change DRIVE LETTER to drive where
> rem directory oe100b\BIN\MFGBKUP.BAT is located.
> rem b) Verify path to Mfgsys60\oe100b\bin and edit if necessary.
> rem c) Edit drive letter and path to database location.
> rem d) Edit drive letter and path to where back should be placed
> rem e) Create the BACKUP directory where backup file will be placed
> rem f) copy the BACKMFG.BAT file OUT of the Mfgsys60 folder and paste
> rem it into any other directory were it will be called on.
> rem (i.e. Backup, oe100b\Bin, scripts, etc.)
> echo Running Epicor Vantage live ONLINE Backup...
> @echo off
> e:\epicor904\oe101c\bin\_mprshut e:\epicor904\db\mfgsys -C backup online
> e:\epicor904\backed_up_files\live\Monday\live_online_backup_mon.1 %4 %5 %6
> %7 %8
> %9 >> e:\epicor904\backed_up_files\live\Monday\live_online_backup_mon.Wri
> echo Running Verify...
> @echo off
> e:\epicor904\oe101c\bin\_dbutil prorest e:\epicor904\db\mfgsys
> e:\epicor904\backed_up_files\live\Monday\live_online_backup_mon.1 -vp >>
> e:\epicor904\backed_up_files\live\Monday\live_online_verify_mon.wri
> @echo off & setlocal
> :: set the temp file location
> set tempmail=%temp%\tempmail.%random%.txt
> :: echo the basic headers to the temp file
> echo To: "Backup Users" ^<backup.users@...<backup.users%40yourdomain.local>^>
> > %tempmail%
> echo From: "Backup Programme" ^<no-reply@...<no-reply%40yourdomain.local>^>
> >> %tempmail%
> echo Subject: Monday - Epicor 9 Live Online Backup >> %tempmail%
> :: echo the blank line that separates the header from the body text
> echo.>>%tempmail%
> :: echo the body text to the temp file
> echo The Monday backup for Epicor 9 (Live) Online backup has taken place.>>
> %tempmail%
> echo Please check the 'backup' and 'verify' documents (using Wordpad) for
> any
> errors - \\server\epicor_folder\backed_up_files\live\Monday.>> %tempmail%
> echo If there are any errors present, please consult with the other Backup
> Users.>> %tempmail%
> :: move the temp file to the mail pickup directory
> :: adjust this location for your system
> move %tempmail% C:\Inetpub\mailroot\Pickup
> set tempmail=
> endlocal
> Path for Open Edge 'bin' folder on the server.
> Path to the 'live' database.
> Path to the location of where you want the backup to be created - in our
> case
> backed_up_files/live/monday - followed whatever you want to call the file -
> ours
> is live_online_backup_mon
> This is the location and name for the verification file (which tells you
> how
> many blocks have been written etc). Ours is in the same location as the
> backup
> file.
> Path to Open Edge.
> Everything in red is so the script sends an automatic email to confirm that
> the
> From: lam lam <lamlyew@... <lamlyew%40gmail.com>>
> To: vantage@yahoogroups.com <vantage%40yahoogroups.com>
> Sent: Thu, 27 January, 2011 5:59:54
> Subject: [Vantage] Batch script to backup Progress database
> Hi all
> Is there anybody who can help me out on this matter?
> We have a client whose level of IT knowledge is poor. They request for a
> batch script to backup their progress database into a specific folder in
> the
> server. The accountant will run this script before she leaves work and we
> have programmed the server to copy the contents of the folder into a backup
> external hard disk at 0200 am every day.
> Is there a way to create this script?
> Rgds
> -Lam-
Rgds
-Lam-
Hi all
batch script to backup their progress database into a specific folder in the
Rgds
-Lam-
Hi.
This is an easy script. Why does it need to be manually ran? Why not schedule
it?
Monday folder etc. We then have Thursday 1-4 so we can always restore to a month
This is the script for Monday's - I will explain the important lines below it.
NB: I hold no responsibility if this causes any damage to your data or hardware
etc. Use at your own risk. It works perfectly well for us so there is no reason
why it shouldnt for you, but I would advise testing on the 'test' DB or server.
@echo off
remÂ
remÂ
rem NOTh:
remÂ
remÂ
@echo off
e:\epicor904\backed_up_files\live\Monday\live_online_backup_mon.1 %4 %5 %6 %7 %8
@echo off
echo To: "Backup Users" ^<backup.users@...^> > %tempmail%
echo From: "Backup Programme" ^<no-reply@...^> >> %tempmail%
echo.>>%tempmail%
%tempmail%
echo Please check the 'backup' and 'verify' documents (using Wordpad) for any
Users.>> %tempmail%
set tempmail=
endlocal
Â
Â
Path to the location of where you want the backup to be created - in our case
backed_up_files/live/monday - followed whatever you want to call the file - ours
Â
This is the location and name for the verification file (which tells you how
many blocks have been written etc). Ours is in the same location as the backup
file.
Â
Path to Open Edge.
Â
Everything in red is so the script sends an automatic email to confirm that the
Â
Hi all
Rgds
-Lam-
