Benefits of Crystal Reports over MS Access?
Crystal Report does create temp tables via command feature. The temp table is not created in the database server.
Regards to MS ACCESS vs Crystal - I believe you need to have extensive experience with both programs to come up with conclusion.
At first I thought MS Access was weak in reporting - but as I worked more with it, it turns out to be just as powerful as Crystal. You just need to use the programmer's feature.
Advantage of Crystal is that it can easily be accessible with Vista/Vantage.
Advantage of Access is if you use MS ACCESS GUI as front end to Vista/Vantage.
But overall they are both "Excellent"
My $.02
--- In vantage@yahoogroups.com, Jose Gomez <jose@...> wrote:
> Crystal itself doesn't generate temp tables.
> Crystal is nothing more than a way to display a bunch of data. For example
> in access, you have Tables, Queries, Forms (Which use Queries, Tables) and
> Reports (which pull data out of said tables or queries)
> Crystal is more late the Reports function of MsAccess. You do the queries in
> BAQ's (Business Activity Queries) within Epicor, these generate an XML file
> which you feed to crystal to create the report.
> Yes I would asset that any report you write in MsAccess can be written usin
> BAQ and Crystal (With enough patience)
> For what is worth, you can use Crystal with MsAccess, simply point Crystal
> to your access DB and you can create reports from there.
> *Jose C Gomez*
> *Software Engineer*
> *T: 904.469.1524 mobile
> E: jose@...
> http://www.josecgomez.com
> <http://www.linkedin.com/in/josecgomez> <http://www.facebook.com/josegomez>
> <http://www.google.com/profiles/jose.gomez> <http://www.twitter.com/joc85>
> <http://www.josecgomez.com/professional-resume/>
> <http://www.josecgomez.com/feed/>
> *Quis custodiet ipsos custodes?*
> On Tue, Mar 22, 2011 at 4:25 PM, Todd Gilbert <tgilbert@...> wrote:
> > Jose,
> > Would you assert that any report written in MS Access could be generated
> > in Crystal? Does Crystal allow for the creation of temp tables?
> > Todd G.
> > -----Original Message-----
> > From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf
> > Of Jose Gomez
> > Sent: Tuesday, March 22, 2011 1:16 PM
> > Subject: Re: [Vantage] Benefits of Crystal Reports over MS Access?
> > In 8 and 9 Crystal is the default choice... Ms Access is not even a real
> > reporting tool, mostly a toy, wouldn't use it in a huge enterprise
> > application... The advantages of crystal are endless. Sure its a giant
> > pain,
> > but if you are progress based ODBC is kinda flaky, also having the
> > reports
> > written using BAQ's and Crystal ensures that you can seamlessly
> > integrate it
> > into the application. Using ODBC wrong can bring your DB to its knees.
> > Just my 2 cents
> > *Jose C Gomez*
> > *Software Engineer*
> > E: jose@...
> > On Tue, Mar 22, 2011 at 4:07 PM, <tgilbert@...> wrote:
> > > Just curious to know if anyone can tell me a reason that Crystal
> > Reports
> > > would be the preferred reporting tool over MS Access for anything but
> > the
> > > most basic report?
> > > Thanks!
> > > Todd Gilbert
> > > GCM, Inc.
> > > Vantage 6.1
> > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> > have already linked your email address to a yahoo id to enable access. )
> > (1) To access the Files Section of our Yahoo!Group for Report Builder
> > and Crystal Reports and other 'goodies', please goto:
> > http://groups.yahoo.com/group/vantage/files/.
> > http://groups.yahoo.com/group/vantage/messages
> > (3) To view links to Vendors that provide Vantage services goto:
> > http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
Just curious to know if anyone can tell me a reason that Crystal Reports would be the preferred reporting tool over MS Access for anything but the most basic report?
Thanks!
Todd Gilbert
GCM, Inc.
Vantage 6.1
application... The advantages of crystal are endless. Sure its a giant pain,
but if you are progress based ODBC is kinda flaky, also having the reports
written using BAQ's and Crystal ensures that you can seamlessly integrate it
Just my 2 cents
*Jose C Gomez*
*Software Engineer*
E: jose@...
> most basic report?
> Thanks!
> Todd Gilbert
> GCM, Inc.
> Vantage 6.1
Jose,
Todd G.
Of Jose Gomez
pain,
reports
integrate it
Just my 2 cents
*Jose C Gomez*
*Software Engineer*
E: jose@...
Reports
the
> most basic report?
> Thanks!
> Todd Gilbert
> GCM, Inc.
> Vantage 6.1
I would argue there are things you can't do in Crystal Reports that you
can do in MS Access and vice-versa. The things that MSA cannot do are
not relevant to me architecting reports. Crystal Reports is a refined
and robust reporting tool and MSA is more than a reporting tool but IMO
it's not as powerful as Crystal Reports on the reporting side.
Combine Crystal Reports with SQL (using views, stored procs, UDFs) and
it's rock-solid.
Of Todd Gilbert
Sent: Tuesday, March 22, 2011 4:26 PM
Subject: RE: [Vantage] Benefits of Crystal Reports over MS Access?
Jose,
Todd G.
Behalf
Of Jose Gomez
pain,
reports
integrate it
Just my 2 cents
*Jose C Gomez*
*Software Engineer*
E: jose@... <mailto:jose%40josecgomez.com>
Reports
the
> most basic report?
> Thanks!
> Todd Gilbert
> GCM, Inc.
> Vantage 6.1
*Jose C Gomez*
*Software Engineer*
E: jose@...
> Jose,
> Todd G.
> Of Jose Gomez
> pain,
> reports
> integrate it
> Just my 2 cents
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> Reports
> the
> > most basic report?
> > Thanks!
> > Todd Gilbert
> > GCM, Inc.
> > Vantage 6.1
Vic you are right that Crystal can't do some of the stuff that access does,
but that's bc Crystal is just a reporting tool, while access attempts to
play in all fields (DB, Query Designer and Even UI)
However the Reporting Side (Actual honest to God reports) I would wager you
can do the same if not more with Crystal
I agree with you that going with SQL Or Progress and using BAQ's, Stored
Procedures or a combination there off, is a solid solution.
*Jose C Gomez*
*Software Engineer*
E: jose@...
> it's rock-solid.
> Of Todd Gilbert
> Jose,
> Todd G.
> Behalf
> Of Jose Gomez
> pain,
> reports
> integrate it
> Just my 2 cents
> *Jose C Gomez*
> *Software Engineer*
> Reports
> the
> > most basic report?
> > Thanks!
> > Todd Gilbert
> > GCM, Inc.
> > Vantage 6.1
Vic,
By SQL, do you mean SQL Server tools? If so, how does that work with a
Progress db? (Sorry...I'm relatively new to all of this.)
Todd
Of Vic Drecchio
Sent: Tuesday, March 22, 2011 1:34 PM
it's rock-solid.
Behalf
Of Todd Gilbert
Jose,
Todd G.
Behalf
Of Jose Gomez
pain,
reports
integrate it
Just my 2 cents
*Jose C Gomez*
*Software Engineer*
Reports
the
> most basic report?
> Thanks!
> Todd Gilbert
> GCM, Inc.
> Vantage 6.1
Todd
You wouldn't use SQL Sever if you were using Progress its either or. Unless
you buy the replication server and then you can SQL Server for reporting
purposes only.
*Jose C Gomez*
*Software Engineer*
E: jose@...
On Tue, Mar 22, 2011 at 4:47 PM, Todd Gilbert <tgilbert@...> wrote:
> Vic,
> Todd
> Of Vic Drecchio
> it's rock-solid.
> Behalf
> Of Todd Gilbert
> Jose,
> Todd G.
> Behalf
> Of Jose Gomez
> pain,
> reports
> integrate it
> Just my 2 cents
> *Jose C Gomez*
> *Software Engineer*
> Reports
> the
> > most basic report?
> > Thanks!
> > Todd Gilbert
> > GCM, Inc.
> > Vantage 6.1
Yeah, exactly what Jose said. If you are a Progress customer,
unfortunately your back-end magic is limited due to the archaic Progress
database and admin interface (OK, I'm ready for all you Progress lovers
to start attacking me). :-)
I couldn't imagine doing my job with a Progress database. SQL is the
only choice IMO.
You could, technically, use SQL Server or SQL Server Express and link to
the Progress database via ODBC to do data mining, forensics, etc....
Back in the day when I was Progress I'd use Access or Excel to do my
"back end" forensics and troubleshooting. What a pain.
So nice to have SQL and run a few SQL queries to see WTH is going on
when you have problems/questions/ etc.
Derailed this conversation (sorry), but I will say Crystal Reports is
10x the reporting tool that Access is. Nothing compares AFAIK.
Vic
Of Todd Gilbert
Sent: Tuesday, March 22, 2011 4:47 PM
Vic,
Todd
Behalf
Of Vic Drecchio
it's rock-solid.
Behalf
Of Todd Gilbert
Jose,
Todd G.
Behalf
Of Jose Gomez
pain,
reports
integrate it
Just my 2 cents
*Jose C Gomez*
*Software Engineer*
Reports
the
> most basic report?
> Thanks!
> Todd Gilbert
> GCM, Inc.
> Vantage 6.1
I will let the progress comments slide ;-)
But I will agree that if you don't have much experience Sql is the better
choice
Sent from mobile
> only choice IMO.
> Vic
> Of Todd Gilbert
> Vic,
> Todd
> Behalf
> Of Vic Drecchio
> it's rock-solid.
> Behalf
> Of Todd Gilbert
> Jose,
> Todd G.
> Behalf
> Of Jose Gomez
> pain,
> reports
> integrate it
> Just my 2 cents
> *Jose C Gomez*
> *Software Engineer*
> Reports
> the
>> most basic report?
>> Thanks!
>> Todd Gilbert
>> GCM, Inc.
>> Vantage 6.1
Crystal over Access.
Well for anything using the customer table you'll need Crystal, unless you use the ODBC embedded query which really slows down the report.
If its not a requirement to print it, I prefer using excel so they can manipulate the data easily.
Like most things its down to preference and experience with a tool.
My 2p.
Wayne
I agree with Vic. IMO, and IMC (In my case.... HA, just thought of that), Access is more of a Data Management tool and Crystal is designed specifically as a Reporting tool; I even utilize Access as my data-source for Crystal for some tasks.
I know Access has Reporting capabilities, forms design and obviously the 100%/user friendly interface with the more commercial software..... but Crystal is a more robust Reporting tool, especially when you require graphical elements and formatting.
Regards.
Roel Martinez
ERP Analyst
SABRE TUBULAR STRUCTURES (tm)
www.sabretubularstructures.com<http://www.sabretubularstructures.com/>
8653 E. Hwy 67 | Alvarado, TX 76009
Phone: 817-852-1700 ext. 11858 | Direct Line: 817-852-1858 |Fax: 817-852-1705
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Vic Drecchio
Sent: Tuesday, March 22, 2011 4:00 PM
only choice IMO.
Vic
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf
Of Todd Gilbert
Vic,
Todd
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
[mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> ] On
Behalf
Of Vic Drecchio
To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
it's rock-solid.
Behalf
Of Todd Gilbert
Jose,
Todd G.
Behalf
Of Jose Gomez
pain,
reports
integrate it
Just my 2 cents
*Jose C Gomez*
*Software Engineer*
E: jose@...<mailto:jose%40josecgomez.com> <mailto:jose%40josecgomez.com>
On Tue, Mar 22, 2011 at 4:07 PM, <tgilbert@...<mailto:tgilbert%40gcmfg.com>
Reports
the
> most basic report?
> Thanks!
> Todd Gilbert
> GCM, Inc.
> Vantage 6.1
http://groups.yahoo.com/group/vantage/files/.<http://groups.yahoo.com/group/vantage/files/>
You are mistaken my friend. Access is much more powerful than Crystal
which is a piece of junk - like you said it's a giant pain. I've spent
about 500 hours using Crystal and much more with Access - give me Access
any day of the week.
Of Jose Gomez
Sent: Tuesday, March 22, 2011 3:16 PM
pain,
reports
integrate it
Just my 2 cents
*Jose C Gomez*
*Software Engineer*
E: jose@...
Reports
the
> most basic report?
> Thanks!
> Todd Gilbert
> GCM, Inc.
> Vantage 6.1
I've written over 100 Crystal reports and over 1000 Access reports.
There is nothing in Crystal that I can't do in Access - and generally do
it quicker.
Lon
Of Jose Gomez
Sent: Tuesday, March 22, 2011 3:38 PM
does,
you
*Jose C Gomez*
*Software Engineer*
E: jose@...
you
IMO
> it's rock-solid.
Behalf
> Of Todd Gilbert
> Jose,
generated
> Todd G.
On
> Behalf
> Of Jose Gomez
real
> pain,
> reports
> integrate it
> Just my 2 cents
> *Jose C Gomez*
> *Software Engineer*
> Reports
but
> the
> > most basic report?
> > Thanks!
> > Todd Gilbert
> > GCM, Inc.
> > Vantage 6.1
For me it's the other way around. I use Crystal for basic reports and MS Access for complex reports. Crystal does a fine job of simple, linked table reports. The BAQ language itself is very limited, compared to MS Access or SQL queries. It drives me nuts that you can't use wildcard characters in BAQs.
I love both and there are workarounds to prevent "dragging the DB to its knees". For years I was told how badly your database performance would degrade when you ODBC to it but from personal experience, my Access reports are usually MUCH faster than the crystal ones. When I build Access databases with MANY queries I usually import a subset of data into access when the DB starts. This makes your queries run much faster. Otherwise, I've found that if you chain enough queries together, it will time out.
As others have probably mentioned, there are some Vantage fields that are too large for ODBC/Access to handle but once you figure out which tables they are and how to create a view you can work around them.
You can also use MS Access to combine multiple datasources, which we do frequently. We have several databases that track data outside of Vantage's capabilities but we still farm some of the data out of Vantage.
My $0.02
> Thanks!
> Todd Gilbert
> GCM, Inc.
> Vantage 6.1
Agreed.
Both programs have strengths and weaknesses, but I can create much more complex data analysis programs in Access that I can in Crystal. Combine that with a user friendly UI and automation possibilities through code and macros and Access is far from a useless toy. Crystal does have some advantages though.
Brian
> My $0.02
> > Thanks!
> > Todd Gilbert
> > GCM, Inc.
> > Vantage 6.1
I didn't anticipate such an emotional topic! Now I don't feel so bad
about going around and around with our network admin.
Thanks to everyone who chimed in.
Todd G.
Of B_Stinger
Sent: Friday, March 25, 2011 5:38 AM
Subject: [Vantage] Re: Benefits of Crystal Reports over MS Access?
Agreed.
advantages though.
Brian
characters in BAQs.
it will time out.
Vantage.
> My $0.02
> > Thanks!
> > Todd Gilbert
> > GCM, Inc.
> > Vantage 6.1
Sorry to reopen a somewhat painful topic...I am interested in getting
some detail on what it would take to copy our Vantage 6.1 Progress
database into a SQL Server database in order to take advantage of its
reporting tools.
Is this where a SQL Replication Server would be employed? I only see
"replication server" mentioned on the Epicor site in the context of
E9.05.
I would like to set up a Data Warehouse of sorts in a SQL Server
database using filtered data from our Progress database. I know I can
do this with Access so I assume I can do it with SQL Server.
Any info is much appreciated.
Todd Gilbert
GCM, Inc.
Vantage 6.1
Of Jose Gomez
Sent: Tuesday, March 22, 2011 1:52 PM
Todd
Unless
purposes only.
*Jose C Gomez*
*Software Engineer*
E: jose@...
wrote:
> Vic,
> Todd
Behalf
> Of Vic Drecchio
you
IMO
> it's rock-solid.
On
> Behalf
> Of Todd Gilbert
> Jose,
generated
> Todd G.
> Behalf
> Of Jose Gomez
real
> pain,
> reports
> integrate it
> Just my 2 cents
> *Jose C Gomez*
> *Software Engineer*
> Reports
but
> the
> > most basic report?
> > Thanks!
> > Todd Gilbert
> > GCM, Inc.
> > Vantage 6.1
We use the SQL reporting tools (SSRS) with Vantage 6.1 for the same
reasons, but we don't use replication server. We have several DTS
packages (DTS in SQL Server 2000, renamed to something I can't remember
in later versions) that pulls data from the 6.1 Progress database via
ODBC and copies it into temporary tables in the SQL database. If you're
using ODBC via MS Access right now, it's the same concept, same driver &
DSN. Our SSRS reports pull data from those temporary tables. Most of
the DTS packages are scheduled nightly (works well) and a few are
on-demand, executed from a stored procedure that provides the report
data (works, but slow).
Contact me off-list if you want more details or examples.
In Epicor 9 (in testing, going live soon!), we choose to have a SQL
backend database, to avoid all these DTS packages. Our SSRS reports
converted pretty smoothly.
Brian.
Of Todd Gilbert
Sent: Tuesday, April 05, 2011 10:53 AM
Subject: [Vantage] Replication Server (Was "Benefits of Crystal Reports
over MS Access?")
reporting tools.
E9.05.
Todd Gilbert
GCM, Inc.
Vantage 6.1
Behalf
Of Jose Gomez
Todd
Unless
purposes only.
*Jose C Gomez*
*Software Engineer*
wrote:
> Vic,
> Todd
Behalf
> Of Vic Drecchio
you
IMO
> it's rock-solid.
On
> Behalf
> Of Todd Gilbert
> Jose,
generated
> Todd G.
> Behalf
> Of Jose Gomez
real
> pain,
> reports
> integrate it
> Just my 2 cents
> *Jose C Gomez*
> *Software Engineer*
> Reports
but
> the
> > most basic report?
> > Thanks!
> > Todd Gilbert
> > GCM, Inc.
> > Vantage 6.1
