It can be a bit intimidating starting out from scratch with the lack of documentation on the product. Since time is money, you might consider taking their (epicor's) two day course to get you started. It is worth it in my opinion. You may be likely spend an equivalent in time wasted beating your head figuring it out on your own... What documentation there is makes a lot more sense once you've been lead through building a couple work flows.
Rob Bucek
Production Control Manager
PH: (715) 284-5376 ext 311
Mobile: (715)896-0590
FAX: (715)284-4084
[Description: cid:1.234354861@...]<http://www.dsmfg.com/>
(Click the logo to view our site)<http://www.dsmfg.com/>
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of pbparker
Sent: Thursday, October 13, 2011 3:57 PM
Subject: [Vantage] Best way to start with Service Connect?
I've searched the group here and didn't find what the best way to start working with SC is. There doesn't seem to be any real tutorials that I can see that at least give you the basics of incoming and outgoing connections, etc.
The only thing I have really is a lab book from Perspective 2009 however the files for the course are not available. I checked the Channel zip file in the files area and it doesn't match the 2009 course.
Anyways, anyone have any good tips or know of any tutorial documents or even have the Perspectives files so I can try working through this workbook?
Thanks..
Patrick Parker
Rob Bucek
FAX: (715)284-4084
Thanks..
Patrick Parker
