Bills of Operations in Multi Plant
I have the same Bill of Operation for one part number in multiple plants. I want to be able to use the same Bill of Operation for that same part number in multiple plants. When I setup the part, I created a revision for the part but it only gives me the option to put it in one plant. I have set up the operation (since operations can be shared amongst the company) and assigned a resource group to the operation (the resource groups are set up in each plant individually since resources are at the plant level). I thought since the operation is shared that I would be able to use the same bill of operation for that part number in both plants.
Is anyone using multi plants with the same part numbers, same bill of operations/materials and manufacturing them in both plants? I do not want to set up an alternate routing for it since the operations are exactly the same. Nothing between the two plants are different. I also do not want to set up alternate routings because in the near future we will be implementing Epicor at another set of our plants that again use the same part number, same bills of materials for that part number. Does anyone have any insight on how I can set these parts up to use the same bill of operations amongst plants?
Thank you!
Lauren Hellings
CPI Global One - Core Team Member
[cid:image001.jpg@01CBB9A2.09FC95E0]
Business Analyst
Office: 281-207-0667 x26
Cell: 832-472-1736
Fax: 281-207-0672
email: lauren.hellings@...<mailto:lauren.hellings@...>
www.c-p-i.com<http://www.c-p-i.com/>
[cid:image002.jpg@01CBB9A2.09FC95E0]
----------Legal Disclaimer----------
The information contained in this message may be privileged and confidential, and is intended solely for the use of the named addressee. No other person is authorized to access, copy or re-use this message (or any information contained herein). If you are not the intended recipient, please notify us immediately by replying to this message and delete it from your computer.
