Brilliant. Thanks. Sent from Yahoo Mail on Android
Hi all,
I am setting up our system so that we can begin to use Requisitions, RFQ's and PO suggestions.
In my Buyers Workbench tree I have some change suggestions and change suggestions, but when I click on them it just raises an empty suggestions window.
How can I clear these out?
Andy
From that window or you can open new PO suggestion entry from the menu. Click on search icon, set option to return all rows.
Expand the search window so you can see the buyer column and sort by the buyer column. the blanks ones will be at the top to select.
You can also run a full PO suggestions regenerative which will clear the file and rebuild completely.
Sent: Friday, October 31, 2014 8:50 AM
Subject: [Vantage] Blank Purchase Suggestions
Hi all,
Andy
CONFIDENTIALITY NOTICE
The information contained in this communication, including attachments, is privileged and confidential. It is intended only for the exclusive use of the addressee. If the reader of this message is not the intended recipient, or the employee or agent responsible for delivering it to the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please notify us at 727-578-6280 and immediately delete the communication.
