Blank size converison & quote module 8.03
Or you can check out the samples located in the Custom\bo\sample
folder. You should be able to easily convert your .p program into a
super procedure.
--- In vantage@yahoogroups.com, "Mark Wonsil" <mark_wonsil@...> wrote:
> > We are currently testing 8.03.305. In Vantage 5.0 we have a VB form
> > (QuoteMtl) where the user enters length, width, thickness, and
alloy.
> > It runs a .p program and returns square foot requirement to Qty/
parent
> > field on the material detail screen. How do others do this in 8.03?
> We use the configurator for that but...
> I don't see why you couldn't add user-defined fields to the form and
call a VB
> routine (instead of Progress) to do the same with a customization.
> Mark W.
(QuoteMtl) where the user enters length, width, thickness, and alloy.
It runs a .p program and returns square foot requirement to Qty/ parent
Dan Shallbetter
States Electric Mfg.
I don't see why you couldn't add user-defined fields to the form and call a VB
Mark W.
