Blank Title 49742
Hello fellow groupies,
I just had to edit all 50 of my client registries to get the help files to
work on 6.1. We have a 2000 network with 2000 and XP clients. I did it from
my client with this batch file. As always CYA by trying this out on a test
machine first. When you run the script it will prompt you for a machine
name. It then displays the value of the key for that machine and prompts
the user for a Y/N response to make the change. If you enter Y it will make
the change and then display the new value.
@echo off
rem Vantage 6.10.535 Progress 9.1d0920
rem This program is used to fix the problem with Vantage help files not
displaying.
rem It checks for the existence of a reg key and displays the contents.
Rem It prompts the user to make the change.
rem MArk Dupuis 4/28/06
rem user prompt
set /p _target="Enter the target computer: "
@echo Checking for key on %_target%.
rem Displays all subkeys and values under the registry key
REG QUERY
\\%_target%\HKLM\Software\Microsoft\HTMLHelp\1.x\ItssRestrictions /s
rem user prompt
set /p _addkey="Do you want to add the reg key? y/n: "
rem add reg key to target computer
if %_addkey%==y (
REG add \\%_target%\HKLM\Software\Microsoft\HTMLHelp\1.x\ItssRestrictions
/v MaxAllowedZone /t REG_DWORD /d 0x1
@echo The key has been added to %_target%.
) else (
@echo NO changes made
goto end
rem Displays changed key value
@echo Here is the new value.
REG QUERY
:end
pause
Mark Dupuis
_____
Mario Aguirre
Sent: Wednesday, May 10, 2006 2:31 PM
Subject: RE: [Vantage]
Me three. Thank you. Maybe, should be posted in the user's group
files...Thanks again.
Mario Aguirre - IT Manager
Lakin General Corp.
Of Bruce Butler
Sent: Wednesday, May 10, 2006 1:23 PM
Me too.
Thank you,
Bruce Butler
IT Manager
Knappe & Koester, Inc.
_____
Of Ben Belzer
Sent: Tuesday, May 09, 2006 5:48 PM
Perfect... mind sending that my way?
Much appreciated...
Ben
Of Chad Brown
Sent: Tuesday, May 09, 2006 1:31 PM
Subject: Re: [Vantage]
you will need to edit the registry to keep vantage help working. I have
the regedit file you can just run, and will do it for you. easy.
Chad Brown
Ben Belzer wrote:
> Anyone seen any issues with SP1 for Server 2003? I am running
6.10.535
> and I plan to upgrade to SP1, and I hope I don't get surprised.
> Thanks,
> Ben
> Ben Belzer
> IT Manager
> TCI Precision Metals
> 800.234.5613.W
> 310.323.1255.F
> bbelzer@... <mailto:bbelzer@...>
> www.tciprecision.com <http://www.tciprecision.com/>
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> (1) To access the Files Section of our Yahoo!Group for Report Builder
> Yahoo! Groups Links
Yahoo! Groups Links
SPONSORED LINKS
Manufacturing software
<http://groups.yahoo.com/gads?t=ms
<http://groups.yahoo.com/gads?t=ms&k=Manufacturing+software&w1=Manufactu>
ring+software&w2=Membership+database+software&w3=Database+mortgage+softw
are&w4=Pda+database+software&w5=Database+management+software&w6=Database
+marketing+software&c=6&s=188&.sig=OG5F3819UOUOg63i0bu6kA>
Membership database software
<http://groups.yahoo.com/gads?t=ms&k=Membership+database+software&w1=Man>
ufacturing+software&w2=Membership+database+software&w3=Database+mortgage
+software&w4=Pda+database+software&w5=Database+management+software&w6=Da
tabase+marketing+software&c=6&s=188&.sig=N5BGdur84p-jyuOomcQdbQ>
Database mortgage software
<http://groups.yahoo.com/gads?t=ms&k=Database+mortgage+software&w1=Manuf>
acturing+software&w2=Membership+database+software&w3=Database+mortgage+s
oftware&w4=Pda+database+software&w5=Database+management+software&w6=Data
base+marketing+software&c=6&s=188&.sig=8rvcSQnCqJhTCZu-0Si39A>
Pda database software
<http://groups.yahoo.com/gads?t=ms&k=Pda+database+software&w1=Manufactur>
ing+software&w2=Membership+database+software&w3=Database+mortgage+softwa
re&w4=Pda+database+software&w5=Database+management+software&w6=Database+
marketing+software&c=6&s=188&.sig=u3KQrTRPAQfsWIT39aHDkg>
Database management software
<http://groups.yahoo.com/gads?t=ms&k=Database+management+software&w1=Man>
tabase+marketing+software&c=6&s=188&.sig=R3CF3ODPY4gwjDZjykQYvw>
Database marketing software
<http://groups.yahoo.com/gads?t=ms&k=Database+marketing+software&w1=Manu>
facturing+software&w2=Membership+database+software&w3=Database+mortgage+
software&w4=Pda+database+software&w5=Database+management+software&w6=Dat
abase+marketing+software&c=6&s=188&.sig=lmBkRUiBtvHI1u5dkymDcw>
_____
YAHOO! GROUPS LINKS
* Visit your group "vantage
<http://groups.yahoo.com/group/vantage> " on the web.
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service <http://docs.yahoo.com/info/terms/> .
_____
SPONSORED LINKS
marketing+software&c=6&s=188&.sig=u3KQrTRPAQfsWIT39aHDkg> Database
management software
YAHOO! GROUPS LINKS
SPONSORED LINKS
Manufacturing
<http://groups.yahoo.com/gads?t=ms&k=Manufacturing+software&w1=Manufacturing
+software&w2=Membership+database+software&w3=Database+mortgage+software&w4=P
da+database+software&w5=Database+management+software&w6=Database+marketing+s
oftware&c=6&s=188&.sig=OG5F3819UOUOg63i0bu6kA> software
Membership
<http://groups.yahoo.com/gads?t=ms&k=Membership+database+software&w1=Manufac
turing+software&w2=Membership+database+software&w3=Database+mortgage+softwar
e&w4=Pda+database+software&w5=Database+management+software&w6=Database+marke
ting+software&c=6&s=188&.sig=N5BGdur84p-jyuOomcQdbQ> database software
Database
<http://groups.yahoo.com/gads?t=ms&k=Database+mortgage+software&w1=Manufactu
ring+software&w2=Membership+database+software&w3=Database+mortgage+software&
w4=Pda+database+software&w5=Database+management+software&w6=Database+marketi
ng+software&c=6&s=188&.sig=8rvcSQnCqJhTCZu-0Si39A> mortgage software
Pda
<http://groups.yahoo.com/gads?t=ms&k=Pda+database+software&w1=Manufacturing+
software&w2=Membership+database+software&w3=Database+mortgage+software&w4=Pd
a+database+software&w5=Database+management+software&w6=Database+marketing+so
ftware&c=6&s=188&.sig=u3KQrTRPAQfsWIT39aHDkg> database software
Database
<http://groups.yahoo.com/gads?t=ms&k=Database+management+software&w1=Manufac
ting+software&c=6&s=188&.sig=R3CF3ODPY4gwjDZjykQYvw> management software
Database
<http://groups.yahoo.com/gads?t=ms&k=Database+marketing+software&w1=Manufact
uring+software&w2=Membership+database+software&w3=Database+mortgage+software
&w4=Pda+database+software&w5=Database+management+software&w6=Database+market
ing+software&c=6&s=188&.sig=lmBkRUiBtvHI1u5dkymDcw> marketing software
_____
YAHOO! GROUPS LINKS
* Visit your group "vantage <http://groups.yahoo.com/group/vantage> "
on the web.
<http://docs.yahoo.com/info/terms/> Terms of Service.
_____
Lakin General Corp.
Of Bruce Butler
Me too.
Thank you,
Bruce Butler
IT Manager
_____
Of Ben Belzer
Much appreciated...
Ben
Of Chad Brown
Chad Brown
6.10.535
> Thanks,
> Ben
> Ben Belzer
> IT Manager
> 800.234.5613.W
> 310.323.1255.F
> Yahoo! Groups Links
Yahoo! Groups Links
SPONSORED LINKS
_____
YAHOO! GROUPS LINKS
_____
SPONSORED LINKS
management software
YAHOO! GROUPS LINKS
