I am needing this same thing i was able to get it to work if you move the bpm to a base processing it will work but this is not a best practice as it can mess with base functionality so i am researching other means has anyone attempted using application studio for this?
The way the Kinetic calls are structured you need to do this in the UI. It’s a fairly easy change:
Open Application Studio, search for Erp.UI.APInvoiceEntry and either open an existing custom layer or create a new one from the base.
Go to Events and add a new event:
Property
Value
Event ID
blueskyerp_NoVendorCarryForward
Description
Stop the new invoice copying the previous invoice's supplier (Blue Sky ERP)
Trigger Type
Event
Trigger Hook
After
Trigger Target
BeforeGetNew
Add one action, row-update:
Property
Value
EpBinding (column)
TransView.vendorID
Value
(leave blank)
It’s only the before and after get new events that use the TransView.vendorID - so it’s safe to blank it out. Blanking it out sending a blank value to ChangeVendorID, which in turn leaves the field empty for user population.
