Does anyone know if there is a business object method out there to return the primary sales rep for a territory?
This rest call will return json with the primary sales rep code.
Or you can use a business object method: adapterSalesTer.GetData(“YourTerritoryID”)
SalesTerAdapter adapterSalesTer = new SalesTerAdapter(this.oTrans);
adapterSalesTer.BOConnect();// Declare and Initialize Variables // TODO: You may need to replace the default initialization with valid values as required for the BL method call. string stringId = ((string)(edvQuoteHed.dataView[edvQuoteHed.Row]["TerritoryID"])); // Call Adapter method System.Data.DataSet dsSalesTer = adapterSalesTer.GetData(stringId); if(dsSalesTer.Tables["SalesTer"].Rows[0] != null) { //MessageBox.Show(dsSalesTer.Tables["SalesTer"].Rows[0]["PrimeSalesRepCode"].ToString()); PrimSalesRep = dsSalesTer.Tables["SalesTer"].Rows[0]["PrimeSalesRepCode"].ToString(); }
