BOM and Product Configurator
Ok, thanks for your help, I will give this a try. I appreciate your
willingness to help
Thank You,
Brad Ebright
MGS Inc.
178 Muddy Creek Church Rd.
Denver, PA 17517
(717)336-7528
_____
Steven Gotschall
Sent: Thursday, July 02, 2009 3:22 PM
Subject: Re: [Vantage] BOM and Product Configurator
I'm not sure. I never had to do this.
I would first make a backup of my database. I would then recreate the
method and see what happens. If it doesn't work, maybe Epicor support can
help.
If you have an earlier backup when your configurator was intact, you could
restore this to another database and use a utility from Epicor that allows
you to export the configurator from one database and import it into another.
I've used this before and it works really well, but the downside to this is
that they charge you for the utility.
From: Brad Ebright <bebright@mgsmail. <mailto:bebright%40mgsmail.com> com>
To: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
Sent: Thursday, July 2, 2009 2:59:47 PM
Subject: RE: [Vantage] BOM and Product Configurator
So if they are there, do I just have to recreate the bom and method and
everything should be back to normal or what would be the next step if the
stuff is there?
Thank You,
Brad Ebright
MGS Inc.
Denver, PA 17517
(717)336-7528
_____
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On Behalf
Of
Steven Gotschall
Sent: Thursday, July 02, 2009 2:51 PM
To: vantage@yahoogroups .com
There is no built in way to access them, but you could create a BAQ that
displays all fields in each table. Its any table that begins with Pc.
PcInValue contains the saved input values, PCRules contains the configurator
rules, PcVerDynLst contains the dynamic lists used in your configurator, and
there are others.
____________ _________ _________ __
From: Brad Ebright <bebright@mgsmail. <mailto:bebright% 40mgsmail. com> com>
To: vantage@yahoogroups <mailto:vantage% 40yahoogroups.. com> .com
Sent: Thursday, July 2, 2009 1:47:34 PM
Where are the pc tables at?
Thank You,
Brad Ebright
MGS Inc.
Denver, PA 17517
(717)336-7528
_____
From: vantage@yahoogroups .com [mailto:vantage@ yahoogroups .com] On Behalf
Of
Steven Gotschall
Sent: Thursday, July 02, 2009 12:50 PM
You could check the pc tables and see if your role rules are still there.
role rules are not deleted when the part or operation they are assigned to
are deleted from the method. I don't know if this is true if the entire rev
is deleted and I'm not sure if other parts of the configurator would still
be there.
From: brad.ebright <bebright@mgsmail. <mailto:bebright% 40mgsmail. com> com>
To: vantage@yahoogroups <mailto:vantage% 40yahoogroups. com> .com
Sent: Thursday, July 2, 2009 12:09:47 PM
Subject: [Vantage] BOM and Product Configurator
Well i spent about a week setting up a configurator. . Today, i went back in
to check something only to find out that the BOM and Method were gone, which
in turn means that configurator is gone. Is there anyway of getting this
back without having to re-do everything? I think I alreay know my answer,
but this is worth a shot...
Brad
Well i spent about a week setting up a configurator. Today, i went back in to check something only to find out that the BOM and Method were gone, which in turn means that configurator is gone. Is there anyway of getting this back without having to re-do everything? I think I alreay know my answer, but this is worth a shot...
Brad
You could check the pc tables and see if your role rules are still there. role rules are not deleted when the part or operation they are assigned to are deleted from the method. I don't know if this is true if the entire rev is deleted and I'm not sure if other parts of the configurator would still be there.
Well i spent about a week setting up a configurator.. Today, i went back in to check something only to find out that the BOM and Method were gone, which in turn means that configurator is gone. Is there anyway of getting this back without having to re-do everything? I think I alreay know my answer, but this is worth a shot...
Brad
Thank You,
Brad Ebright
MGS Inc.
Denver, PA 17517
(717)336-7528
_____
Steven Gotschall
be there.
From: brad.ebright <bebright@mgsmail. <mailto:bebright%40mgsmail.com> com>
Brad
There is no built in way to access them, but you could create a BAQ that displays all fields in each table. Its any table that begins with Pc. PcInValue contains the saved input values, PCRules contains the configurator rules, PcVerDynLst contains the dynamic lists used in your configurator, and there are others.
Thank You,
Brad Ebright
MGS Inc.
Denver, PA 17517
(717)336-7528
_____
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On Behalf Of
Steven Gotschall
be there.
Brad
stuff is there?
Thank You,
Brad Ebright
MGS Inc.
Denver, PA 17517
(717)336-7528
_____
Steven Gotschall
there are others.
Thank You,
Brad Ebright
MGS Inc.
Denver, PA 17517
(717)336-7528
_____
Of
Steven Gotschall
be there.
Brad
I would first make a backup of my database. I would then recreate the method and see what happens. If it doesn't work, maybe Epicor support can help.
If you have an earlier backup when your configurator was intact, you could restore this to another database and use a utility from Epicor that allows you to export the configurator from one database and import it into another. I've used this before and it works really well, but the downside to this is that they charge you for the utility.
stuff is there?
Thank You,
Brad Ebright
MGS Inc.
Denver, PA 17517
(717)336-7528
_____
Steven Gotschall
there are others.
Thank You,
Brad Ebright
MGS Inc.
Denver, PA 17517
(717)336-7528
_____
Of
Steven Gotschall
be there.
Brad
