BOM Data Export Problem
yeah, I think I'm going to have write that query. The export is in Progress. Also, the export report/import to other dbase, is the less desired option.
--- In vantage@yahoogroups.com, "Brian Roberts" <broberts@...> wrote:
> Epicor only stores the BOM one level 1 deep in the database, as you've
> discovered. It builds the full BOM tree at report time only. Your
> choices are to export an Epicor report (you can customize the crystal
> format to reduce the export size), or to write your own query - not that
> hard if you're on SQL.
> Brian.
> Of Hutchinson Ind
> Sent: Tuesday, July 17, 2012 9:36 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: BOM Data Export Problem
> Thanks Brian,
> I tried the below. Didn't solve the problem. The tables below create a
> listing of BOMs 1 level deep. When you actually look at the BOM listing
> report, it drills down to the lowest part. Thanks for your feedback
> thought!
> --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ,
> "Brian Roberts" <broberts@> wrote:
> > PartRev for revisions, PartOpr for operations, PartMtl for child
> > material. Remember to join by RevisionNum & AltMethod (if you have
> > multiple revisions), and PartMtl.RelatedOperation is the link to
> > PartOpr.OprSeq.
> > Brian.
> > From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On
> Behalf
> > Of Hutchinson Ind
> > Sent: Tuesday, July 17, 2012 8:41 AM
> > To: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> > Subject: [Vantage] BOM Data Export Problem
> > ...I've been trying to export BOMs from Epicor 904 but have been
> having
> > problems. Has anyone had any success and could provide tips? What I've
> > tried so far...
> > Action
> > Exporting reports "BOM Listing" and "Summarized BOM"
> > Result
> > XML file generated was too large(600mb) to import into database. Also,
> > due to size, report crashed Epicor
> > Action
> > Extract data from PartBOM table(SQL Server)
> > Result
> > This is a temp table that only contains data as the report is being
> > generated. Data is progressively deleted while report is created.
> > Some other questions
> > Where are the BOMs stored? Epicor has said custom code keeps it
> > temporary storage but the data has to reside "somewhere".
> > Any help would be much appreciated
> > John
...I've been trying to export BOMs from Epicor 904 but have been having problems. Has anyone had any success and could provide tips? What I've tried so far...
Action
Result
XML file generated was too large(600mb) to import into database. Also, due to size, report crashed Epicor
Action
Result
This is a temp table that only contains data as the report is being generated. Data is progressively deleted while report is created.
Where are the BOMs stored? Epicor has said custom code keeps it temporary storage but the data has to reside "somewhere".
John
PartOpr.OprSeq.
Brian.
Of Hutchinson Ind
tried so far...
Action
Result
Action
Result
John
Thanks Brian,
I tried the below. Didn't solve the problem. The tables below create a listing of BOMs 1 level deep. When you actually look at the BOM listing report, it drills down to the lowest part. Thanks for your feedback thought!
> PartOpr.OprSeq.
> Brian.
> Of Hutchinson Ind
> tried so far...
> Action
> Result
> Action
> Result
> John
Brian.
Of Hutchinson Ind
Thanks Brian,
thought!
> PartOpr.OprSeq.
> Brian.
Behalf
> Of Hutchinson Ind
having
> tried so far...
> Action
> Result
> Action
> Result
> John
