BOM Duplication
Hi Toby,
I am trying to do the same thing and having a tough time figuring out
where all the tables are, especially since the buyer would like more
info on the report, like preferred vendor and on order quantity. I see
that in Vantage preferred vendor is a "view" so I am not sure how to
pull it of the tables. If you or anyone has figured this out I would
appreciate seeing how you accomplished that.
Lisa Shea
iCyt Mission Technology
--- In vantage@yahoogroups.com, "Manasa Reddy" <manasa@...> wrote:
> Only if the report is a crystal report, then that is true....if it is
> progress you have to create from scratch.
> Look at the report definitions to see if the BOM Listing report is
> there...if it is then it is easy to just modify, if not, then you have
> M. Manasa Reddy
> manasa@...
> P: 630-806-2000
> F: 630-806-2001
> Of Toby Boogerd
> Sent: Wednesday, April 16, 2008 9:43 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] BOM Duplication
> I am running 8.03.404 and I want to take the current BOM Listing report
> that was created by Vantage and make it my own report in Crystal. How is
> this possible? I thought I remembered previous posts stating you can run
> a canned report and that it creates some file somewhere (assuming xml on
> local drive) and using that file you can use Crystal to create or modify
> the report for your own use.
> Toby Boogerd
> Information Systems
> 712-324-4854 x1119
> NOTICE: This email may contain confidential and proprietary information
> of Rosenboom Machine & Tool, Inc. By opening any enclosed files, the
> recipient agrees not to use, reproduce, disclose, or manufacture its
> contents, in whole or in part, without prior written consent of
Toby Boogerd
Information Systems
712-324-4854 x1119
M. Manasa Reddy
manasa@...
P: 630-806-2000
F: 630-806-2001
Of Toby Boogerd
Toby Boogerd
Information Systems
712-324-4854 x1119
