Sal,
I agree with Brian. Writing a BOM importer is not easy, and unless
you are really good at writing S/C workflows, I wouldn't even try...
The Excel thing is really easy... Try this:-
Select a part that already has a BOM from the MPF and then access the
method tracker. Select the materials tab, and then the list tab. Now
you see the data grid. You will also see the little grey column on
the left side of the grid - right-click anywhere on this. From the
context menu, click the "copy all" option. Open Excel, and then
simply paste this data into Excel. What is important here is that we
now have the column data requirements that we need for our import.
Save this as a template for future reference.
Now replace the data with the real BOM data you want to upload.
Select the data block in Excel and copy it. Go back to Vantage, find
the part you want to upload the BOM to, and check this out to the ECO
group in the usual manner. Access the materials data grid, and right-
click on the little grey column again. This time select the "paste
insert" option. If everything has gone according to plan, your BOM
will appear in Vantage as if by magic!
You must ensure that the data is clean ( for example all parts must
exist in the MPF already ), as any duff data will cause the process
to stop and you will need to go back and try again.
Once you get the hang of it, its really easy.
Let me know how you get on...
Nick
--- In vantage@yahoogroups.com, "idiabos" <idiabos@...> wrote:
> Hi Nick,
> I didn't receive the BOM importer sample workflow from Epicor. I'll
> check with my rep on that. The reason I was working on this was for
> our engineering group that export BOM info from a schematic into an
> excel document. But if you say that I can import easily from excel
I
> may just go that route. What is involved in this? I have never
> imported anything into Vantage before. Thanks!!!
> -Sal
> --- In vantage@yahoogroups.com, "nmtaylor1969" <n.taylor@> wrote:
> > Sal,
> > Doesn't Epicor supply you with a BOM importer as one of the
sample
> > workflows that you get with S/C ?
> > How many BOM's do you have to import ? I found importing them via
> > Excel and pasting them into the BOM editor materials data grid to
be
> > just as easy...!
> > Thanks,
> > Nick
> > --- In vantage@yahoogroups.com, "idiabos" <idiabos@> wrote:
> > > Does anyone have a basic BOM upload Workflow for Service
Connect
> > they
> > > are willing to share? I have been trying to create one myself
to no
> > > avail. Any help would be most appreciated!!!
> > > -Sal
