Boolean (ie. Check Box) in VB Forms
Mark,
After doing some 'fiddling', I believe that the radio set returns a character in to the field table.character01, which you can specify for each Item in the Radio Button List. You do it like this:
Item 1,xx
Item 2,2
Item 3,how are you doing?
The above code in the Radio Set Attributes would return "xx" if the first button was clicked, "2" if the second, and "how are you doing?" if the third. Then you can use the character01 field in reports, progress routines, etc.
Troy Funte
Liberty Electronics
----- Original Message -----
Sent: Wednesday, April 17, 2002 11:01 AM
Subject: RE: [Vantage] Boolean (ie. Check Box) in VB Forms
Can a radio set return a Boolean value?
Mark Smith
IT Manager
Innerpac, Inc.
(708) 863-8300
From: sarah.vareschi@... [mailto:sarah.vareschi@...]
Sent: Tuesday, April 16, 2002 1:09 PM
Yes, you can add a Boolean checkbox, it's called a 'toggle-box'. It's on
the palette in VB Forms. It's 'checkbox01' (etc.) in the field list.
Yahoo! Groups Sponsor
ADVERTISEMENT
<http://rd.yahoo.com/M=215002.1990895.3471383.1261774/D=egroupweb/S=17050071
83:HM/A=1000239/R=0/*http://ads.x10.com/?bHlhaG9vaG0xLmRhd=1018983255%3eM=21
5002.1990895.3471383.1261774/D=egroupweb/S=1705007183:HM/A=1000239/R=1>
ADVERTISEMENT
Is there a way to put a check box that would indicate a Boolean Yes/No on a VB Form, that could then be tapped into in a Crystal or RB report?
I only see the types: String, Date, Number in the field options.
If so, could someone please explain the process?
Troy Funte
Liberty Electronics
Troy,
You can add a toggle-box_x to your VB form. Take note of the field
name and
use it as a criteria. In other words If CheckBox03 = yes,
then...<whatever>.
I use it to identify a certain customer's parts that I have to do a
quarterly report
on. Let me know if you need any more info.
Regards,
Thanks everyone. I somehow missed the CheckBox01 fields in the list. I think I've got it worked out.
Troy Funte
Liberty Electronics
Sent: Tuesday, April 16, 2002 1:59 PM
Subject: [Vantage] Boolean (ie. Check Box) in VB Forms
Troy Funte
Liberty Electronics
ADVERTISEMENT
Mark Smith
IT Manager
Innerpac, Inc.
(708) 863-8300
ADVERTISEMENT
When you add a radio_set, it uses a character field. For me, I am always
running out of character fields in VB forms, so I would not use the toggle
box if a simple Boolean was required. Also, although you could probably
make this work as a Boolean, since it is a character field, it would take
some maneuvering in your report writer.
