BOReader displaying blank column
Hello,
I keep getting a blank column in Job Manager using BO Reader.
Here is my code.
// Custom code for JobManagerForm
// Created: 14/09/2018 14:02:13
using System;
using System.ComponentModel;
using System.Data;
using System.Diagnostics;
using System.Windows.Forms;
using Erp.Adapters;
using Erp.UI;
using Ice.Lib;
using Ice.Adapters;
using Ice.Lib.Customization;
using Ice.Lib.ExtendedProps;
using Ice.Lib.Framework;
using Ice.Lib.Searches;
using Ice.UI.FormFunctions;
using Ice.Proxy.Lib; // BOReader
public class Script
	EpiUltraGrid myGrid;
	private BOReaderImpl _boReader;
		myGrid = (EpiUltraGrid)csm.GetNativeControlReference("f1959434-7042-4fd9-a610-4c6863adbdfe");
		myGrid.DisplayLayout.Bands[0].Columns.Add("BatchNo_c","BatchNo");
		myGrid.InitializeRow += new Infragistics.Win.UltraWinGrid.InitializeRowEventHandler(grdMatLst_InitializeRow);
		BOReaderImpl _boReader = WCFServiceSupport.CreateImpl<BOReaderImpl>((Ice.Core.Session)oTrans.Session, Epicor.ServiceModel.Channels.ImplBase<Ice.Contracts.BOReaderSvcContract>.UriPath);
	private void grdMatLst_InitializeRow(object sender, Infragistics.Win.UltraWinGrid.InitializeRowEventArgs e)
		if(!String.IsNullOrEmpty(e.Row.Cells["BatchNo_c"].Value.ToString()))
		DataSet ds = _boReader.GetRows("JobHead","BatchNo_c='" +e.Row.Cells["BatchNo_c"].Value.ToString()+ "'","BatchNo_c");
		if(ds.Tables[0].Rows.Count > 0 )
		e.Row.Cells["BatchNo_c"].Value = ds.Tables[0].Rows[0]["BatchNo_c"];
		// Begin Custom Code Disposal
		// End Custom Code Disposal
		_boReader = null;
Thanks again.
You have a global _boReader variable, but then in Initialize you create a new local variable, so the global one never gets set perhaps.
This must be changed to
Also in DestroyCustomCode shouldn’t this be -=
I’ll give it a go.
Hi Haso,
It’s giving me this error now.
Forgot the semi-colon but it’s still blank :frowning:
The next thing change “JobHead” to “Erp:BO:Job”
All done but still coming back blank :smiley:
I’ve tired
changing GetList from GetRow made no difference because I thought it may struggle with UD columns.
I included JobNum because I thought it may look at that.
		if(!String.IsNullOrEmpty(e.Row.Cells["JobNum"].Value.ToString()))
		DataSet ds = _boReader.GetList("Erp:BO:Job","JobNum='" +e.Row.Cells["JobNum"].Value.ToString()+ "'","BatchNo_c");
Current code:
using System;
using System.Data;
using Erp.Adapters;
using Erp.UI;
using Ice.Lib;
using Ice.Adapters;
using Erp.BO;
using Ice.BO;
public class Script
		myGrid.InitializeRow -= new Infragistics.Win.UltraWinGrid.InitializeRowEventHandler(grdMatLst_InitializeRow);
		_boReader = null;
Still god damn blank :angry:
Nah didn’t return anything. :confused:
Sorry I meant with Erp:BO:Job
DataSet ds = _boReader.GetRows("Erp:BO:Job","BatchNo_c='" +e.Row.Cells["BatchNo_c"].Value.ToString()+ "'", string.Empty);
Nothing my man… I don’t know how many times I’ve sighed now :smiley:
It’s just returning blank anything I do.
Execute it through REST/Swagger and see what is returned.
Can you really filter using UD columns?
Can you try filtering using a base column?
Can you display other columns or everything is blank?
Hi Jonathan,
I can get the information through rest no problems whatsoever.
It’s still bugging me why the column isn’t displaying anything.
Kind regards,
Aaron.
My current code:
using System;
using System.Data;
using Erp.Adapters;
using Erp.UI;
using Ice.Lib;
using Ice.Adapters;
using Ice.Core;
using Erp.BO;
using Ice.BO;
public class Script
    			DataSet ds = _boReader.GetRows("Erp:BO:Job","JobNum = '" + e.Row.Cells["JobNum"].Value.ToString() + "'","JobNum, BatchNo_c");
    				e.Row.Cells["BatchNo_c"].Value = ds.Tables[0].Rows[0]["BatchNo_c"].ToString();
    		_boReader = null;
Anyone able to help me get BatchNo_c displaying from JobHead?
Got it, I needed Erp:BO:JobEntry not Erp:BO:Job
Thanks again.
Hi @aarong ,
I am getting below mentioned error while running above code
Compiling Custom Code …
----------errors and warnings------------
Error: CS0308 - line 41 (239) - The non-generic type ‘Epicor.ServiceModel.Channels.ImplBase’ cannot be used with type arguments
** Compile Failed. **
Could you please suggest how to resolve this issue. This issue is coming due to below line
_boReader = WCFServiceSupport.CreateImpl((Ice.Core.Session)oTrans.Session, Epicor.ServiceModel.Channels.ImplBase<Ice.Contracts.BOReaderSvcContract>.UriPath);
Try
_boReader = WCFServiceSupport.CreateImpl<BOReaderImpl>((Ice.Core.Session)oTrans.Session, Ice.Proxy.Lib.BOReaderImpl.UriPath);
What version are you on? 10.2.100.9
