BPM Action Queue table
Lets they try to start Action Process task for first if they want to have async BPM actions:
System Management\Business Process Management\General Operations\Action Process
These tables can be cleared via ABL code or OE Architect.
My BPM async processor isn't working. If I set them to run synchronously they work fine, but not when set asynchronously. Doing some checking I find that the BPACTIONQUEUE and BPACTIONQUEUEDATA tables have over 2000 lines of data each... indicating (to me at least) that the BPM is working and sending stuff to the queue but for some reason the queue isn't doing its part.
This is all test data and I don't mind losing it in the least. Is there any way I can just clear out these tables?
And does that seem like a probably cause of the hiccup?
Thanks and Merry Christmas!
Ernie Lowell
Diba Industries
I assume you are running the BPM Action Process, required for ASYNC
procs?
Regards,
Stephen
Of Elizabeth
Sent: 23 December 2010 15:56
Subject: [Vantage] BPM Action Queue table
Ernie Lowell
Diba Industries
Yes I am, it runs on startup and is set for continuous processing every minute. Shutting it off and then running it manually has no effect. Additionally, there is an old (and I thought deleted) BPM that DOES run every time I restart the appservers. It just sends an empty email (as there is no "tt" table for it to draw data from), and I think this is what it bugging up the works.
Ernie Lowell
Diba Industries
> procs?
> Regards,
> Stephen
> Of Elizabeth
> Ernie Lowell
> Diba Industries
I would clear the two tables, perform the action check it gets
serialized into the queue, then run the action process manually.
Also check the action log, and or add further logging into your BPM if
required.
When it runs the process reads the bp action queue and creates temporary
.p procedure from the action queue data in the work directory then
executes this so you can also check here for any issues.
If something in the queue caused the process to loop or terminate, each
time it started it would only perform one item then exit.
Hope that helps
Regards,
Stephen
Of Elizabeth
Sent: 23 December 2010 18:45
Subject: [Vantage] Re: BPM Action Queue table
Ernie Lowell
Diba Industries
> procs?
> Regards,
> Stephen
Behalf
> Of Elizabeth
synchronously
2000
there
> Ernie Lowell
> Diba Industries
