BPM - Add Date03 and Date04 field to OrderHed from Customer
Hi Nathan,
I finally got a chance to get back to this BPM and tried your BO.Method
Quote.CreateOrder process and it works great. Since you included the
OrderDtl table in the query I was also able to update another field in
that table. Thank you very much for your help.
Regards,
Linda
Of bonner.nathan
Sent: Friday, September 11, 2009 10:47 AM
Subject: [Vantage] Re: BPM - Add Date03 and Date04 field to OrderHed
from Customer
Linda,
Try this on BO.Method Quote.CreateOrder as a Post Process 4GL:
For each ttQuoteHed, each Customer where (Customer.Company =
ttQuoteHed.Company and Customer.CustNum = ttQuoteHed.CustNum), each
ttQuoteDtl where (ttQuoteDtl.Company = ttQuoteHed.Company and
ttQuoteDtl.QuoteNum = ttQuoteHed.QuoteNum), each OrderDtl where
(OrderDtl.Company = ttQuoteDtl.Company and OrderDtl.QuoteNum =
ttQuoteDtl.QuoteNum and ttQuoteDtl.QuoteLine = OrderDtl.QuoteLine), each
OrderHed where (OrderHed.Company = OrderDtl.Company and
OrderHed.OrderNum = OrderDtl.OrderNum) no-lock.
Run lib\UpdateTableBuffer.p(input BUFFER OrderHed:HANDLE,'Date01',
Customer.Date01).
End.
This is another way of accomplishing the same thing...
NB
"Linda Lowney" <llowney@...> wrote:
> Hi Nathan,
> Oops! I spoke too soon. I created a query that looks at the date
> fields in the customer and in the order and when I ran it to check if
> the BPM worked I was looking at the wrong date columns... having a
brain
> fart I guess. No date fields were copied from the customer to the
> ordered table when I created the order from quote entry.
> Regards,
> Linda
Behalf
> Of Linda Lowney
> Sent: Friday, September 11, 2009 9:31 AM
> Subject: RE: [Vantage] Re: BPM - Add Date03 and Date04 field to
OrderHed
> from Customer
> Hi Nathan,
> That worked beautifully!! Thank you very much. Why wouldn't that
method
> show up in the trace log? I'm using the tracing log in
Vantage/Options.
> Is there a better utility to use to find the methods that are being
> called?
> Regards,
> Linda
> Behalf
> Of bonner.nathan
> Sent: Wednesday, September 09, 2009 2:42 PM
> from Customer
> Linda,
> The BO.Method you want is under Sales Order and not under Quote.
> As before, feel free to call if you are still having trouble,
> NB
> "Linda Lowney" <llowney@> wrote:
> > Hi Nathan,
> > Maybe I'm looking in the wrong place, but If I go into Method
> > Directives/Method Code search, then pick the Business Object Quote
> there
> > is no GetNewOrderHed. When I run a trace the only methods that I see
> > are:
> > DefaultOrderFields
> > CheckCustomerCreditLimit
> > CreateOrder
> > GetById
> > None of these methods show the ttOrderHed temporary table in the
list
> > when I click on the Advanced button.
> > I was able to access the ttOrderHed table on the Sales Order side
> while
> > adding a new order manually and transfer the fields from the
customer
> to
> > the order. It is only in Quote Entry that I'm having a problem. We
> > create sales orders both ways.
> > Regards,
> > Linda
> Behalf
> > Of bonner.nathan
> > Sent: Wednesday, September 09, 2009 11:36 AM
> > from Customer
> > Linda,
> > The first method I described will work for you.
> > Quote - Create Order (Order Wizard) calls the BO.Method,
> > 'SalesOrder.GetNewOrderHed' so put your BPM there.
> > Script should look something like the following if it is the
Customer
> > Table you wish to pull from:
> > For each ttOrderHed where ttOrderHed.RowMod = 'A', each ttOrderDtl
> where
> > ttOrderDtl.Company = ttOrderHed.Company and ttOrderDtl.OrderNum =
> > ttOrderHed.OrderNum no-lock.
> > Find First QuoteHed where QuoteHed.Company = ttOrderDtl.Company and
> > QuoteHed.QuoteNum = ttOrderDtl.QuoteNum no-lock.
> > If available QuoteHed then do:
> > Find First Customer where Customer.Company = QuoteHed.Company and
> > Customer.CustNum = QuoteHed.CustNum no-lock.
> > If available Customer then do:
> > Assign ttOrderHed.Date01 = Customer.Date01.
> > End.
> > If not available Customer then return.
> > End.
> > If not available QuoteHed then return.
> > End.
> > > Hi Nathan,
> > > I am pulling the fields from the Customer table to the OrderHed
> table,
> > > but there is no ttOrderHed temp table when using the Quote -
> > CreateOrder
> > > method.
> > > Regards,
> > > Linda
> > Behalf
> > > Of bonner.nathan
> > > Sent: Wednesday, September 09, 2009 10:35 AM
OrderHed
> > > from Customer
> > > Linda,
> > > Not sure if you are trying to get fields from OrderHed to
QuoteHed,
> > from
> > > QuoteHed to OrderHed or from Customer to QuoteHed. Which ever it
is
> > the
> > > basic approach will be the same though the BO.Method and Table and
> > > Table.Field names will change.
> > > BO.Methods: SalesOrder.GetNewOrderHed (for SO's created directly
> from
> > > the quote through the Order Wizard) Other BO.Methods will depend
on
> > the
> > > results of your Trace Logging while executing the business process
> you
> > > are trying to catch.
> > > Conditions: (NONE)
> > > Actions: Synchronously execute 4GL
> > > Script 1 (assuming you want to update a field on the TempTable):
> > where
and
> > > Assign ttOrderHed.Date01 = QuoteHed.Date01.
> > > End.
> > > End.
> > > Script 2 (assuming you want to update a field on the Database
> Table):
> > where
and
> > > Run lib\UpdateTableBuffer.p(input BUFFER QuoteHed:HANDLE,
'Date01',
> > > ttOrderHed.Date01).
> > > /*Target Table Name = QuoteHed Target Field Name = Date01 Source
> > > Table.Field = ttOrderHed.Date01. Change to suit needs.*/
> > > End.
> > > End.
> > > Email or call if you'd like more help with this:
> > > bonner.n@
> > > totalplastics.com
> > > 616.717.1613
> > > Nathan Bonner
> > > "lindalowney" <llowney@> wrote:
> > > > Hi Group,
> > > > I have to pull a couple of user defined date fields into the
order
> > > header table from the customer table when we create a new order
(or
> > > change the customer on an order). I managed to do this easily in
> Order
> > > Entry, but I can't figure out how to do it in Quote Entry when an
> > order
> > > is created from the quote. There are only a few methods that are
> > called
> > > and none of them seem to have a ttOrderHed table that I can hook
> into.
> > > > Have any of you ever done anything like this and would be
willing
> to
> > > share?
> > > > Regards,
> > > > Linda
Hi Group,
I have to pull a couple of user defined date fields into the order header table from the customer table when we create a new order (or change the customer on an order). I managed to do this easily in Order Entry, but I can't figure out how to do it in Quote Entry when an order is created from the quote. There are only a few methods that are called and none of them seem to have a ttOrderHed table that I can hook into.
Have any of you ever done anything like this and would be willing to share?
Regards,
Linda
Linda,
Not sure if you are trying to get fields from OrderHed to QuoteHed, from QuoteHed to OrderHed or from Customer to QuoteHed. Which ever it is the basic approach will be the same though the BO.Method and Table and Table.Field names will change.
BO.Methods: SalesOrder.GetNewOrderHed (for SO's created directly from the quote through the Order Wizard) Other BO.Methods will depend on the results of your Trace Logging while executing the business process you are trying to catch.
Conditions: (NONE)
For each ttOrderHed where ttOrderHed.RowMod = 'A', each ttOrderDtl where ttOrderDtl.Company = ttOrderHed.Company and ttOrderDtl.OrderNum = ttOrderHed.OrderNum no-lock.
Find First QuoteHed where QuoteHed.Company = ttOrderDtl.Company and QuoteHed.QuoteNum = ttOrderDtl.QuoteNum no-lock.
End.
End.
Script 2 (assuming you want to update a field on the Database Table):
Run lib\UpdateTableBuffer.p(input BUFFER QuoteHed:HANDLE, 'Date01', ttOrderHed.Date01).
/*Target Table Name = QuoteHed Target Field Name = Date01 Source Table.Field = ttOrderHed.Date01. Change to suit needs.*/
End.
End.
bonner.n@
totalplastics.com
616.717.1613
Nathan Bonner
--- In vantage@yahoogroups.com, "lindalowney" <llowney@...> wrote:
> Hi Group,
> Regards,
> Linda
Hi Nathan,
I am pulling the fields from the Customer table to the OrderHed table,
but there is no ttOrderHed temp table when using the Quote - CreateOrder
method.
Regards,
Linda
Of bonner.nathan
from Customer
Linda,
Conditions: (NONE)
End.
End.
ttOrderHed.Date01).
End.
End.
bonner.n@
totalplastics.com
616.717.1613
Nathan Bonner
> Hi Group,
share?
> Regards,
> Linda
Linda,
Quote - Create Order (Order Wizard) calls the BO.Method, 'SalesOrder.GetNewOrderHed' so put your BPM there.
Script should look something like the following if it is the Customer Table you wish to pull from:
Find First Customer where Customer.Company = QuoteHed.Company and Customer.CustNum = QuoteHed.CustNum no-lock.
End.
End.
End.
--- In vantage@yahoogroups.com, "Linda Lowney" <llowney@...> wrote:
> Hi Nathan,
> method.
> Regards,
> Linda
> Of bonner.nathan
> from Customer
> Linda,
> Conditions: (NONE)
> End.
> End.
> ttOrderHed.Date01).
> End.
> End.
> bonner.n@
> totalplastics.com
> 616.717.1613
> Nathan Bonner
> > Hi Group,
> share?
> > Regards,
> > Linda
Hi Nathan,
Directives/Method Code search, then pick the Business Object Quote there
are:
DefaultOrderFields
CreateOrder
GetById
None of these methods show the ttOrderHed temporary table in the list
I was able to access the ttOrderHed table on the Sales Order side while
adding a new order manually and transfer the fields from the customer to
Regards,
Linda
Of bonner.nathan
from Customer
Linda,
End.
End.
End.
> Hi Nathan,
CreateOrder
> method.
> Regards,
> Linda
Behalf
> Of bonner.nathan
> from Customer
> Linda,
from
the
the
> Conditions: (NONE)
where
> End.
> End.
where
> ttOrderHed.Date01).
> End.
> End.
> bonner.n@
> totalplastics.com
> 616.717.1613
> Nathan Bonner
> > Hi Group,
order
called
> share?
> > Regards,
> > Linda
Linda,
NB
> Hi Nathan,
> are:
> DefaultOrderFields
> CreateOrder
> GetById
> Regards,
> Linda
> Of bonner.nathan
> from Customer
> Linda,
> End.
> End.
> End.
> > Hi Nathan,
> CreateOrder
> > method.
> > Regards,
> > Linda
> Behalf
> > Of bonner.nathan
> > from Customer
> > Linda,
> from
> the
> the
> > Conditions: (NONE)
> where
> > End.
> > End.
> where
> > ttOrderHed.Date01).
> > End.
> > End.
> > bonner.n@
> > totalplastics.com
> > 616.717.1613
> > Nathan Bonner
> > > Hi Group,
> order
> called
> > share?
> > > Regards,
> > > Linda
orry for the delay. I have been putting out fires since yesterday morning. We upgraded from 405A to 408B over the weekend to resolve a handful of issues that were fixed in the Service Pack/Patch releases. While we did fix several of the issues we were experiencing we had a few new issues that crept in as a result of the upgrade. Anyway, below is a screenshot of what we are looking for. Basically, we just need to have a date range or a cut-off date “filter” added to the Production Detail report to allow us to run the report with a specific cutoff date for a job. For example, the way the report currently runs for a job it shows everything to present. I want to be able to run the report, say in the middle of August and be able to have a cutoff date of July 31. Hope that makes sense. Please let me know what you think. Also, I sub
Sent from my Verizon Wireless BlackBerry
Hi Nathan,
That worked beautifully!! Thank you very much. Why wouldn't that method
show up in the trace log? I'm using the tracing log in Vantage/Options.
called?
Regards,
Linda
Of bonner.nathan
from Customer
Linda,
NB
> Hi Nathan,
there
> are:
> DefaultOrderFields
> CreateOrder
> GetById
while
to
> Regards,
> Linda
Behalf
> Of bonner.nathan
> from Customer
> Linda,
where
> End.
> End.
> End.
> > Hi Nathan,
table,
> CreateOrder
> > method.
> > Regards,
> > Linda
> Behalf
> > Of bonner.nathan
> > from Customer
> > Linda,
> from
> the
from
> the
you
> > Conditions: (NONE)
> where
> > End.
> > End.
Table):
> where
> > ttOrderHed.Date01).
> > End.
> > End.
> > bonner.n@
> > totalplastics.com
> > 616.717.1613
> > Nathan Bonner
> > > Hi Group,
Order
> order
> called
into.
to
> > share?
> > > Regards,
> > > Linda
Hi Nathan,
the BPM worked I was looking at the wrong date columns... having a brain
Regards,
Linda
Of Linda Lowney
Subject: RE: [Vantage] Re: BPM - Add Date03 and Date04 field to OrderHed
from Customer
Hi Nathan,
called?
Regards,
Linda
Behalf
Of bonner.nathan
from Customer
Linda,
NB
> Hi Nathan,
there
> are:
> DefaultOrderFields
> CreateOrder
> GetById
while
to
> Regards,
> Linda
Behalf
> Of bonner.nathan
> from Customer
> Linda,
where
> End.
> End.
> End.
> > Hi Nathan,
table,
> CreateOrder
> > method.
> > Regards,
> > Linda
> Behalf
> > Of bonner.nathan
> > from Customer
> > Linda,
> from
> the
from
> the
you
> > Conditions: (NONE)
> where
> > End.
> > End.
Table):
> where
> > ttOrderHed.Date01).
> > End.
> > End.
> > bonner.n@
> > totalplastics.com
> > 616.717.1613
> > Nathan Bonner
> > > Hi Group,
Order
> order
> called
into.
to
> > share?
> > > Regards,
> > > Linda
Linda,
Tracing is the best way to find your method. That said, I just looked at the trace from Order Wizard and the 'SalesOrder.GetNewOrderHed' is not in the results.
I don't know of any other/better tools for finding BO.Methods short of just knowing a little about what processes have to happen to support the results you are getting. e.g. When I run the Order Wizard from a Quote I end up with a Sales Order so at some point 'SalesOrder.GetNewOrderHed' must have been called.
A few of the more advanced BPM users put on a WebEx a few months back and made the WebEx recording available. I have downloaded it but haven't had a chance to listen to it yet. I hear it is excellent and may be something you want to checkout to help take your BPM's to the next level.
NB
> Hi Nathan,
> called?
> Regards,
> Linda
> Of bonner.nathan
> from Customer
> Linda,
> NB
> > Hi Nathan,
> there
> > are:
> > DefaultOrderFields
> > CreateOrder
> > GetById
> while
> to
> > Regards,
> > Linda
> Behalf
> > Of bonner.nathan
> > from Customer
> > Linda,
> where
> > End.
> > End.
> > End.
> > > Hi Nathan,
> table,
> > CreateOrder
> > > method.
> > > Regards,
> > > Linda
> > Behalf
> > > Of bonner.nathan
> > > from Customer
> > > Linda,
> > from
> > the
> from
> > the
> you
> > > Conditions: (NONE)
> > where
> > > End.
> > > End.
> Table):
> > where
> > > ttOrderHed.Date01).
> > > End.
> > > End.
> > > bonner.n@
> > > totalplastics.com
> > > 616.717.1613
> > > Nathan Bonner
> > > > Hi Group,
> Order
> > order
> > called
> into.
> to
> > > share?
> > > > Regards,
> > > > Linda
Linda,
For each ttQuoteHed, each Customer where (Customer.Company = ttQuoteHed.Company and Customer.CustNum = ttQuoteHed.CustNum), each ttQuoteDtl where (ttQuoteDtl.Company = ttQuoteHed.Company and ttQuoteDtl.QuoteNum = ttQuoteHed.QuoteNum), each OrderDtl where (OrderDtl.Company = ttQuoteDtl.Company and OrderDtl.QuoteNum = ttQuoteDtl.QuoteNum and ttQuoteDtl.QuoteLine = OrderDtl.QuoteLine), each OrderHed where (OrderHed.Company = OrderDtl.Company and OrderHed.OrderNum = OrderDtl.OrderNum) no-lock.
Run lib\UpdateTableBuffer.p(input BUFFER OrderHed:HANDLE,'Date01', Customer.Date01).
End.
NB
> Hi Nathan,
> Regards,
> Linda
> Of Linda Lowney
> from Customer
> Hi Nathan,
> called?
> Regards,
> Linda
> Behalf
> Of bonner.nathan
> from Customer
> Linda,
> NB
> > Hi Nathan,
> there
> > are:
> > DefaultOrderFields
> > CreateOrder
> > GetById
> while
> to
> > Regards,
> > Linda
> Behalf
> > Of bonner.nathan
> > from Customer
> > Linda,
> where
> > End.
> > End.
> > End.
> > > Hi Nathan,
> table,
> > CreateOrder
> > > method.
> > > Regards,
> > > Linda
> > Behalf
> > > Of bonner.nathan
> > > from Customer
> > > Linda,
> > from
> > the
> from
> > the
> you
> > > Conditions: (NONE)
> > where
> > > End.
> > > End.
> Table):
> > where
> > > ttOrderHed.Date01).
> > > End.
> > > End.
> > > bonner.n@
> > > totalplastics.com
> > > 616.717.1613
> > > Nathan Bonner
> > > > Hi Group,
> Order
> > order
> > called
> into.
> to
> > > share?
> > > > Regards,
> > > > Linda
Hi Nathan,
This one worked for me. Thank you. What you were saying about the
'SalesOrder.GetNewOrderHed' makes sense so maybe I did something wrong.
I'll play around with it some more when I'm done with this project.
Thank you very much for all your help.
Regards,
Linda
Of bonner.nathan
from Customer
Linda,
Customer.Date01).
End.
NB
> Hi Nathan,
brain
> Regards,
> Linda
Behalf
> Of Linda Lowney
OrderHed
> from Customer
> Hi Nathan,
method
Vantage/Options.
> called?
> Regards,
> Linda
> Behalf
> Of bonner.nathan
> from Customer
> Linda,
> NB
> > Hi Nathan,
> there
> > are:
> > DefaultOrderFields
> > CreateOrder
> > GetById
list
> while
customer
> to
> > Regards,
> > Linda
> Behalf
> > Of bonner.nathan
> > from Customer
> > Linda,
Customer
> where
> > End.
> > End.
> > End.
> > > Hi Nathan,
> table,
> > CreateOrder
> > > method.
> > > Regards,
> > > Linda
> > Behalf
> > > Of bonner.nathan
OrderHed
> > > from Customer
> > > Linda,
QuoteHed,
> > from
is
> > the
> from
on
> > the
> you
> > > Conditions: (NONE)
> > where
and
> > > End.
> > > End.
> Table):
> > where
and
'Date01',
> > > ttOrderHed.Date01).
> > > End.
> > > End.
> > > bonner.n@
> > > totalplastics.com
> > > 616.717.1613
> > > Nathan Bonner
> > > > Hi Group,
order
(or
> Order
> > order
> > called
> into.
willing
> to
> > > share?
> > > > Regards,
> > > > Linda
