BPM AutoShipTo Blank Title 89416
Plamen -
You might want to also try:
IF NOT String.IsNullorEmpty(CustCnt_2.Name) THEN CustCnt_2.Name else
"teststring"
This will check if the string is empty too and not just null.
Hope this helps,
Calvin Dekker
Email: calvin@... <mailto:calvin@...>
http://www.codabears.com <http://www.codabears.com>
<http://www.codabears.com/>
*New software/hardware Support & Maintenance Programs
Of plamen21
Sent: Monday, April 26, 2010 11:16 AM
To: calvind
Subject: [Vantage] Re: BPM AutoShipTo
Thanks guys. I just found IsNull() when I saw your responses. Thanks a
lot.
Plamen
"Ross Hughes" <ross.hughes@...> wrote:
> Try this:
> If Not IsNull({CustCnt_2.Name}) then {CustCnt_2.Name} else
"teststring"
> Ross
> -----Original Message-----
Behalf Of
> plamen21
> Sent: Monday, April 26, 2010 10:49 AM
> I am trying this with an if statement but it is not kicking in [the
first if
> does not evaluate properly]. Here is my formula field. Is there
another way
> to check for empty string?
> //Print Contact from Bill To if Ship To Contact is blank
> if {CustCnt_2.Name} <> "" //check if ShipTo Contact is blank
> then {CustCnt_2.Name} //use it if not blank
> else "teststring" //otherwise substitute "teststring"
"Dines, Tim" <tdines@> wrote:
> > Plamen,
> > You can create a calculated field in Crystal that looks for the null
> > values in the shipto fields. When the value is null, put the BillTo
> > data in the calculated fields. Use the calculated fields on the
Crystal
> > Report in place of the ShipTo fields coming from Vantage.
> > Tim Dines
> > Information Technology
> > Steel Parts Manufacturing, Inc.
> > 801 Berryman Pike
> > Tipton, IN 46072
> > Direct: 765-675-5201
> > Cell: 765-437-1402
Behalf
> > Of plamen21
> > Sent: Friday, April 16, 2010 2:04 PM
> > My apologies. I should have started with the ultimate objective.
> > We rely heavily on the printed paper. The customer contact printing
on
> > various forms (Quote/SO Ack./Job Traveler/Service Call Ticket) is
> > crucial to our business. The easier it is to enter them the better.
> > The Crystal reports we are using were designed to print the ShipTo
> > Contact (or blank if there is no ShipTo).
> > I agree that there may be a solution that does not involve a BPM.
> > I know that Vantage will use the Customer info, and it will be
easier to
> > enter the info in just one step, but I haven't found a way to make
> > Crystal accommodate for that.
> > Is there a way to make Crystal [XI] use the Contact
Name/Phone/E-mail
> > from the BillTo on customers without a ShipTo Contact?
> > Plamen
> > Systems Administrator
> > Art Display Co.
> > "Virginia" <vjoseph@> wrote:
> > > Hi Plamen: Unless I am misunderstanding what you are trying to
> > accomplish, you don't think you need a BPM.
> > > >We enter a new client with address/phone, and a contact for them.
> > >When we go to create a ShipTo we have to enter the same info over
> > again.
> > > If the Company name and address for the ShipTo location are the
same
> > as the Company name and the address on the main customer sheet, the
> > ShipTo can remain blank. When you create a Sales Order for this
customer
> > and there is no ShipTo information in the customer table, the sales
> > order automatically populates the Customer name and address from the
> > main customer sheet the ShipTo fields in the sales order.
> > > Virginia Joseph, LLC
> > > Deep Hole Specialists, LLC
> > > 440-543-8157
> > "Sean McDaniel" <smcdaniel@> wrote:
> > > > You could do this through a BPM, but you'd have to do an
advanced
> > BPM
> > > > that hooks into the business objects - a bit tricky.
> > > > If you did a customization then you could access the adapters
and do
> > > > something like this pretty painlessly. Maybe hook into the after
> > adapter
> > > > methods that are available to you to trigger this type of
action.
> > Behalf
> > > > Of plamen21
> > > > Sent: Tuesday, April 13, 2010 4:53 PM
> > > > Subject: [Vantage] BPM AutoShipTo
them.
> > When
again.
> > I am
> > > > looking for a way to create a BPM, maybe in conjunction with a
> > [copy]
> > > > button that would copy all this info into the corresponding
fields
> > of a
> > > > new ShipTo.
> > > > I noticed the file AutoShipTo.bpm by advancebusiness2000 in the
> > > > Files/Bpm folder. unfortunately it is "custom code" and it is
not
> > > > commented and I didn't find a description of what it does
anywhere
> > in
> > > > the messages, and I find it difficult to deconstruct. I imported
it
> > and
> > > > it seems like it assigns consecutive numbers for ShipTo ID and
takes
> > the
> > > > client name for ShipTo Name. ttShipTo.RowMod does not appear in
the
> > data
> > > > dictionary, so I am not sure what role that plays.
> > > > I have seen the tutorial about adding a button to open a web
page,
> > but
> > > > have no idea how to mke it copy a bunch of fields over to the
> > shipto.
> > > > Any help is appreciated.
> > > > Plamen Cheshmedjiev
> > > > Art Display Co.
> > > > [Non-text portions of this message have been removed]
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
have
> (1) To access the Files Section of our Yahoo!Group for Report Builder
and
> http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
We enter a new client with address/phone, and a contact for them. When we go to create a ShipTo we have to enter the same info over again. I am looking for a way to create a BPM, maybe in conjunction with a [copy] button that would copy all this info into the corresponding fields of a new ShipTo.
I noticed the file AutoShipTo.bpm by advancebusiness2000 in the Files/Bpm folder. unfortunately it is "custom code" and it is not commented and I didn't find a description of what it does anywhere in the messages, and I find it difficult to deconstruct. I imported it and it seems like it assigns consecutive numbers for ShipTo ID and takes the client name for ShipTo Name. ttShipTo.RowMod does not appear in the data dictionary, so I am not sure what role that plays.
I have seen the tutorial about adding a button to open a web page, but have no idea how to mke it copy a bunch of fields over to the shipto.
Plamen Cheshmedjiev
Art Display Co.
You could do this through a BPM, but you'd have to do an advanced BPM
If you did a customization then you could access the adapters and do
something like this pretty painlessly. Maybe hook into the after adapter
methods that are available to you to trigger this type of action.
Of plamen21
new ShipTo.
Plamen Cheshmedjiev
Art Display Co.
Hi Plamen,
ttShipTo.RowMod is a field in the temp table that contains an "A" if the
row (record) has been added, "U" if the row has been updated and "D" if
the row has been deleted. I think they are all the available values -
someone please correct me if I am wrong.
Regards,
Linda
Of Sean McDaniel
Sent: Tuesday, April 13, 2010 9:39 PM
Subject: RE: [Vantage] BPM AutoShipTo
Behalf
Of plamen21
new ShipTo.
Plamen Cheshmedjiev
Art Display Co.
It can also have a Null (?) value if the row hasn't changed.
Sent: Wed, April 14, 2010 9:07:28 AM
Â
Hi Plamen,
Regards,
Linda
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On Behalf
Of Sean McDaniel
To: vantage@yahoogroups .com
From: vantage@yahoogroups .com <mailto:vantage% 40yahoogroups. com>
[mailto:vantage@yahoogroups .com <mailto:vantage% 40yahoogroups. com> ] On
Behalf
Of plamen21
To: vantage@yahoogroups .com <mailto:vantage% 40yahoogroups. com>
new ShipTo.
Plamen Cheshmedjiev
Art Display Co.
Hi Plamen: Unless I am misunderstanding what you are trying to accomplish, you don't think you need a BPM.
>We enter a new client with address/phone, and a contact for them. >When we go to create a ShipTo we have to enter the same info over again.
If the Company name and address for the ShipTo location are the same as the Company name and the address on the main customer sheet, the ShipTo can remain blank. When you create a Sales Order for this customer and there is no ShipTo information in the customer table, the sales order automatically populates the Customer name and address from the main customer sheet the ShipTo fields in the sales order.
440-543-8157
> Of plamen21
> new ShipTo.
> Plamen Cheshmedjiev
> Art Display Co.
Aha!
Thanks, guys.
> From: Linda Lowney <llowney@...>
> ÂÂ
> Hi Plamen,
> Regards,
> Linda
> Of Sean McDaniel
> Behalf
> Of plamen21
> new ShipTo.
> Plamen Cheshmedjiev
> Art Display Co.
We rely heavily on the printed paper. The customer contact printing on various forms (Quote/SO Ack./Job Traveler/Service Call Ticket) is crucial to our business. The easier it is to enter them the better.
The Crystal reports we are using were designed to print the ShipTo Contact (or blank if there is no ShipTo).
I know that Vantage will use the Customer info, and it will be easier to enter the info in just one step, but I haven't found a way to make Crystal accommodate for that.
Is there a way to make Crystal [XI] use the Contact Name/Phone/E-mail from the BillTo on customers without a ShipTo Contact?
Plamen
Art Display Co.
> 440-543-8157
> > Of plamen21
> > new ShipTo.
> > Plamen Cheshmedjiev
> > Art Display Co.
Plamen,
data in the calculated fields. Use the calculated fields on the Crystal
Tim Dines
801 Berryman Pike
Tipton, IN 46072
Cell: 765-437-1402
Of plamen21
Plamen
Art Display Co.
again.
> 440-543-8157
BPM
adapter
Behalf
> > Of plamen21
When
I am
[copy]
of a
> > new ShipTo.
in
and
the
data
but
shipto.
> > Plamen Cheshmedjiev
> > Art Display Co.
I am trying this with an if statement but it is not kicking in [the first if does not evaluate properly]. Here is my formula field. Is there another way to check for empty string?
--- In vantage@yahoogroups.com, "Dines, Tim" <tdines@...> wrote:
> Plamen,
> Tim Dines
> 801 Berryman Pike
> Tipton, IN 46072
> Cell: 765-437-1402
> Of plamen21
> Plamen
> Art Display Co.
> again.
> > 440-543-8157
> BPM
> adapter
> Behalf
> > > Of plamen21
> When
> I am
> [copy]
> of a
> > > new ShipTo.
> in
> and
> the
> data
> but
> shipto.
> > > Plamen Cheshmedjiev
> > > Art Display Co.
Try using the length function length({CustCnt_2.Name})=0
Of plamen21
Sent: Monday, April 26, 2010 11:49 AM
> Plamen,
Crystal
> Tim Dines
> 801 Berryman Pike
> Tipton, IN 46072
> Cell: 765-437-1402
Behalf
> Of plamen21
to
> Plamen
> Art Display Co.
> again.
customer
> > 440-543-8157
> BPM
do
> adapter
> Behalf
> > > Of plamen21
> When
again.
> I am
> [copy]
> of a
> > > new ShipTo.
> in
it
> and
takes
> the
the
> data
> but
> shipto.
> > > Plamen Cheshmedjiev
> > > Art Display Co.
Try this:
If Not IsNull({CustCnt_2.Name}) then {CustCnt_2.Name} else "teststring"
Ross
plamen21
> Plamen,
> Tim Dines
> 801 Berryman Pike
> Tipton, IN 46072
> Cell: 765-437-1402
> Of plamen21
> Plamen
> Art Display Co.
> again.
> > 440-543-8157
> BPM
> adapter
> Behalf
> > > Of plamen21
> When
> I am
> [copy]
> of a
> > > new ShipTo.
> in
> and
> the
> data
> but
> shipto.
> > > Plamen Cheshmedjiev
> > > Art Display Co.
Thanks guys. I just found IsNull() when I saw your responses. Thanks a lot.
Plamen
--- In vantage@yahoogroups.com, "Ross Hughes" <ross.hughes@...> wrote:
> Try this:
> Ross
> plamen21
> --- In vantage@yahoogroups.com, "Dines, Tim" <tdines@> wrote:
> > Plamen,
> > Tim Dines
> > 801 Berryman Pike
> > Tipton, IN 46072
> > Cell: 765-437-1402
> > Of plamen21
> > Plamen
> > Art Display Co.
> > again.
> > > 440-543-8157
> > BPM
> > adapter
> > Behalf
> > > > Of plamen21
> > When
> > I am
> > [copy]
> > of a
> > > > new ShipTo.
> > in
> > and
> > the
> > data
> > but
> > shipto.
> > > > Plamen Cheshmedjiev
> > > > Art Display Co.
Good day all,
Our company takes orders and ships from 3 different plants. We are trying to create a Crystal Report, and need to know which table and field contains the Plant in which the order originated.
I appreciate all replies.
Thanks a lot,
Kerry Travis, CGA
Controller
International Name Plate Supplies Ltd.
Plant and Warehouse Code are in the Order Release (OrderRel) file.
Charlie Smith
Smith Business Services / 2W Technologies LLC
www.vistaconsultant.com <http://www.vistaconsultant.com/> /
www.2WTech.com
Of Kerry Travis
Sent: Monday, April 26, 2010 12:08 PM
Subject: [Vantage] Originating Plant re Order
Good day all,
Thanks a lot,
Kerry Travis, CGA
Controller
