BPM calling a function calling a BAQ - BAQ not returning results
I have a BPM calling a function calling a BAQ that is not returning results. The BAQ input is a part number and the output is an average cost. The BPM is a standard data directive that runs when the order detail line is saved.
Function signature:
Signature
Execution parameters:
Add execution parameter code:
Method parameters:
BPM function parameters:
Get average cost code:
When I test the BAQ I get a result:
But when I save the line in order detail I get an error:
Any ideas on why the data set is empty?
most of the images are lost, only first 2 are shown
Yes, you can’t include images from https://epiccare.epicor.com/sys_attachment.do?etc
Attach the actual images.
BAQ returns no results or returns null?
If it me, I’d be writing an Ice.Diagnostics.Log.WriteEvent($“{MyParam}”); first to ensure I was passing what I expected.
Method parameters:
Method parameters
Function parameters
Set average cost
BAQ result:
BAQ result
Error:
Exception
If it was returning null, he would get null reference exception, not this.
I would also add server log trace to dump SQL statement of executed BAQ and parameter values
<add uri="profile://ice/fw/DynamicQuery/BaqStatement" />
That’s a good suggestion, but unless I misunderstood what he is doing, he is calling a BAQ via code. He should be able to log his param (that he is putting in the BAQParamDS) before calling the BAQ no?
sure, you log it before, I log it on query execution. They should be the same if everything is specified correctly. If it is not - this should probably help to know where it when wrong.
