I passed the value to a character variable first and it does not throw the error.
--- In vantage@yahoogroups.com, "mmcwilliams22" <mmcwilliams22@...> wrote:
> Thanks. Looks like my only issue is the size of the field.
> Can the Character be converted so it is accepted?
> Error Detail
> ** Invalid character unit value 1000, Changed to 320. (4132)
> **FILL-IN Character08 will not fit in FRAME in PROGRAM . (4028)
> --- In vantage@yahoogroups.com, John Driggers <waffqle@> wrote:
> > You can do this with ABL. Like so:
> > OUTPUT TO 'c:\filename.txt' APPEND.
> > FOR EACH Part.
> > DISPLAY Part.PartNum. /* This will be written to your file. */
> > END.
> > OUTPUT CLOSE.
> > On Mon, Dec 5, 2011 at 12:41 PM, mmcwilliams22 <mmcwilliams22@>wrote:
> > > Looking to write to a text file when a change is made to a certain field.
> > > Don't want to write this to the server log. What is the best way to append
> > > to a text file using a BPM?
> > > I would prefer to avoid usign the chglog table in Vantage for this.
> > *John Driggers*
> > *High End Dev, System Design, Profit Drinking
> > *:: 904.962.2887*
> > *:: waffqle@*
> > *:: NO FAXES*
