BPM condition lookup 'contains' within field value
Try this:
FOR EACH whsebin WHERE whsebin.desc MATCHES ("*DO NOT USE*").
Ross
--- In vantage@yahoogroups.com, "jim_chance" <jim_chance@...> wrote:
> Is there a way to examine a field in a BPM condition that would examine a field and look for a matching literal contained within the field?
> I need to look for the words "DO NOT USE" in the whsebin.desc field.
> T-SQL code would be:
> select * from whsebin where whsebin.desc like '%DO NOT USE%'
> For anything before or after the literal DO NOT USE
> How can this be done in the BPM condition - perhaps something in the value to wildcard (contains within)?
> Thank you.
Thank you.
