I have a BPM that works sometimes.
I created a DD on DMRHead In Transistion
Condition: ttDMRHead.DMRNum field has changed from any to any
ALso used At least one ADDED row to ttDMRHead
Actions:
> {lib/PublishInfoMsg.i &InfoMsg = '"Some Test"'}.
> DEF VAR ipc-subject AS CHAR NO-UNDO.
> DEF VAR ipc-emailtext AS CHAR NO-UNDO.
> DEF VAR vh-bpmmail AS HANDLE NO-UNDO.
> DEF VAR pl-async AS LOG NO-UNDO.
> DEF VAR pc-comp AS CHAR NO-UNDO.
> DEF VAR pc-from AS CHAR NO-UNDO.
> DEF VAR pc-to AS CHAR NO-UNDO.
> DEF VAR pc-cc AS CHAR NO-UNDO.
> run Bpm/BpmEmail.p persistent set vh-bpmmail.
> pl-async = FALSE.
> pc-from = 'XXXX@CCICMS.COM'.
> pc-to = 'XXXXXX@ccicms.com'.
> pc-comp = cur-comp.
> ipc-subject = "DMR " + string(ttDMRHead.DMRNum) + " has been processed for PartNum: " + ttDMRHead.PartNum + ".".
> /*ipc-subject = "DMR".*/
> ipc-emailtext = "BPM: DD DMRHead InTran - MAS".
> {lib/PublishInfoMsg.i &InfoMsg = '"Some Test2"'}.
> RUN SendEmail in vh-bpmmail(pl-async,
> pc-comp,
> pc-from,
> pc-to,
> pc-cc,
> ipc-subject,
> ipc-emailtext,
> DELETE OBJECT vh-bpmmail NO-ERROR.
When I go to Inspection Processing and FAIL the material, RMA, Inventory, I see the Popup message, but the email does not send most of the time.
My BPM Action Process is running every minute…
> 04/18/17 09:54:37 BPM Action Process - -------------------- Starting --------------------
> 04/18/17 09:54:37 BPM Action Process - PID: 9992; Session: 10.0.93.14::EpicorTest905::9421::a779c9e00e9a281d:-5d11a166:15b777adf9c:-330f
> 04/18/17 09:54:37 BPM Action Process - Started
> 04/18/17 09:54:37 BPM Action Process - Stopped
> 04/18/17 09:54:39 BPM Action Process - -------------------- Starting --------------------
> 04/18/17 09:54:39 BPM Action Process - PID: 11660; Session: 10.0.93.14::Epicor905Print::9405::a779c9e00e9a281d:467099e1:15b7778b4c1:-20ba
> 04/18/17 09:54:39 BPM Action Process - Started
> 04/18/17 09:54:39 BPM Action Process - Processing
> 04/18/17 09:54:39 BPM Action Process - Completed
> 04/18/17 09:54:39 BPM Action Process - Stopped
> 04/18/17 09:55:40 BPM Action Process - -------------------- Starting --------------------
> 04/18/17 09:55:40 BPM Action Process - PID: 13764; Session: 10.0.93.14::Epicor905Print::9405::a779c9e00e9a281d:467099e1:15b7778b4c1:-20af
> 04/18/17 09:55:40 BPM Action Process - Started
> 04/18/17 09:55:40 BPM Action Process - Processing
> 04/18/17 09:55:40 BPM Action Process - AblActionType #61145 - Starting action
> 04/18/17 09:55:41 BPM Action Process - AblActionType #61145 - Action completed
> 04/18/17 09:55:41 BPM Action Process - AblActionType #61146 - Starting action
> 04/18/17 09:55:42 BPM Action Process - AblActionType #61146 - Action completed
> 04/18/17 09:56:28 BPM Action Process - -------------------- Starting --------------------
> 04/18/17 09:56:28 BPM Action Process - PID: 9992; Session: 10.0.93.14::EpicorTest905::9421::a779c9e00e9a281d:-5d11a166:15b777adf9c:-3302
> 04/18/17 09:56:28 BPM Action Process - Started
> 04/18/17 09:56:28 BPM Action Process - Stopped
Here are the emails I rec’d. Once I got the first email, I tried to clean up the code, basically comment in/out stuff, then i was not able to get this going for an hour…then no more emails again.
Any thoughts?
