> In Perspectives 2008 it was mentioned that all BPMs go to 1 directory.In Epicor 9, there is a BPMExec folder (same level as the Server folder) and
> Does anyone have a step by step to create a BPM directories for each
> database i.e. one for live, one for test, etc. etc. I remember that it
> has something to do with the directories and one of the config files
under that is a folder for each database: LiveBPM, TestBPM, PilotBPM, and
TrainingBPM. The folder *must* end in "BPM". Once these are setup, you have
to change your PROPATH on all three appServers to point to correct one for
each database. I believe there's an AnswerBook on EpicWeb that explains this
as well.
Mark W.
