# BPM Exception not stopping transaction? **Category:** [Epicor ERP 10](https://www.epiusers.help/c/e10/5) **Created:** 2017-02-10 17:45 UTC **Views:** 1392 **Replies:** 5 **URL:** https://www.epiusers.help/t/bpm-exception-not-stopping-transaction/37243 --- ## Post #1 by @Aaron_Moreng I have a couple of BPMs to stop the changeing of QuoteDtlPartNum if the draw num field is not blank, one on QuoteHed.ChangePartNum and QuoteHed.ChangePartNumMaster. They are exactly the same conditions. Both BPMs have an exception node to be thrown when the conditions. The when the conditions are met, both BPMs will throw the exception to the user. The weird thing is that the exception does not stop the transaction from going through. I've never seen this behavior with my other exceptions on other BPMs, but these two seem to do nothing other than show the user the exception. Anyone run into this before? --- ## Post #2 by @josecgomez I assume this is Pre Proc? and if so what method? --- ## Post #3 by @markdamen I’ve seen it on InvTransfer.PreCommitTransfer. Epicor Support only suggested moving the BPM to another method, not actually solving the root cause. --- ## Post #4 by @Aaron_Moreng It is on both quotehed.changepartnum and changepartnummaster, both pre processing --- ## Post #5 by @josecgomez Put your Exception on update.... on ChangePartNum or ChangePartNumMaster is mostly just for loading in defaults (such as description etc)... but it wont stop the field from getting updated. --- ## Post #6 by @Aaron_Moreng Hey Jose, I'm working on this now. When I place the Exception on Update, I still get the same behavior on the Quote Form in that it appears to allow the part num to change. It fires the Update method 3 times when the part num field is change, so each time it fires, my exception displays. Because the form behavior seems to be overriding the indent of the BPM, do you recommend building the logic into the form rather than the BPM approach? --- **Canonical:** https://www.epiusers.help/t/bpm-exception-not-stopping-transaction/37243 **Original content:** https://www.epiusers.help/t/bpm-exception-not-stopping-transaction/37243
