BPM for engineering workbench
Greg, thanks for the solution. I appreciate your help!
Could someone forward a code for a BPM whereby when an engineer is adding a material to a BOM, there is a warning message that comes up when the material being added has a typecode of saleskit.
Here's what I tried in the conditions, without success.  I select the condition whereby the designated query is equal to one.  The query has EcoMtl and Part tables joined together, with a criteria of typecode = k
thanks for any suggestions
This works on EngWorkBench.Update.  If fires when the material is saved.
HTH
Condition: Number of rows in the FindKit query is not less than 1
query
for each ttECOMtl no-lock  ,  each Part no-lock  where (ttECOMtl.Company = Part.Company and ttECOMtl.MtlPartNum = Part.PartNum ) and  part.TypeCode = "K"
Action: raise exception.
Sent: Tuesday, March 31, 2015 10:52 AM
Subject: [Vantage] BPM for engineering workbench
CONFIDENTIALITY NOTICE
The information contained in this communication, including attachments, is privileged and confidential. It is intended only for the exclusive use of the addressee. If the reader of this message is not the intended recipient, or the employee or agent responsible for delivering it to the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please notify us at 727-578-6280 and immediately delete the communication.
