BPM for Inventory Transfer
Hi,
I can only go by what was said.
By the way, they got a work around for me 405. But I only want to send an email and relies on post-processing.
Basically, the bpm is set up life so.
1) Pre - Posting set conditions. IN our case a warehouse code.
2) Post - Processing set dependency on the pre-processing.
3) Post - processing set email
But there are problems , e.g. you can't show informational message even with the above.
--- In vantage@yahoogroups.com, "laraines422" <laraines422@...> wrote:
> Oops - pressed SEND too soon.
> It should read:
> I hope that it's true that it's scheduled for 409. They told me in April
> that
> the SCR was scheduled for "Epicor 904.504 service pack release with no
> version
> for 8.03.4x."
> Laraine
> April that no SCR was scheduled for "Epicor 904.504 service pack release
> with no version for 8.03.4x.
> > Laraine
> > --- In vantage@yahoogroups.com, "Nigel Kerley" nigel.kerley@ wrote:
> > > Thanks for the info.
> > > --- In vantage@yahoogroups.com, "brychanwilliams" <brychanwilliams@>
> wrote:
> > > > Hi,
> > > > I have spoken support(uk), apparently a fix is scheduled for 409.
> > > > --- In vantage@yahoogroups.com, "Nigel Kerley" <nigel.kerley@>
> wrote:
> > > > > Only discovered it recently. Haven't gotten round to logging it
> yet.
> > > > > Nigel.
> <brychanwilliams@> wrote:
> > > > > > Nigel,
> > > > > > Thanks, are epicor support aware of this?
> wrote:
> > > > > > > I needed to create a BPM against Inv Transfer as well and
> the only action I could get working against any of the InvTransfer.***
> BOs was to "Raise an Exception".
> > > > > > > (We're on v406a/Progress)
> > > > > > > Maybe you could achieve the same thing with a BAM/Alert
> Program on the PartTran table.
> > > > > > > Nigel.
> > > > > > > > Hi,
> > > > > > > > I am trying to create a BPM for Inventory transfer, which
> will email people when a particular warehouse is involved with the
> serial numbers.
> > > > > > > > I have used the tracing log and that seems to indicate
> that it is using invtransfer. I tagging against the committransfer but
> can't seem to fire it.
> > > > > > > > I was wondering if anybody could help me out on this.
Hi,
I am trying to create a BPM for Inventory transfer, which will email people when a particular warehouse is involved with the serial numbers.
I have used the tracing log and that seems to indicate that it is using invtransfer. I tagging against the committransfer but can't seem to fire it.
I needed to create a BPM against Inv Transfer as well and the only action I could get working against any of the InvTransfer.*** BOs was to "Raise an Exception".
Maybe you could achieve the same thing with a BAM/Alert Program on the PartTran table.
Nigel.
--- In vantage@yahoogroups.com, "brychanwilliams" <brychanwilliams@...> wrote:
> Hi,
Nigel,
> Nigel.
> --- In vantage@yahoogroups.com, "brychanwilliams" <brychanwilliams@> wrote:
> > Hi,
Only discovered it recently. Haven't gotten round to logging it yet.
Nigel.
> Nigel,
> > Nigel.
> > > Hi,
Hi,
> Nigel.
> > Nigel,
> > > Nigel.
> > > > Hi,
> Hi,
> > Nigel.
> > > Nigel,
> > > > Nigel.
> > > > > Hi,
I hope that it's true that it's scheduled for 409. They told me in April that no SCR was scheduled for "Epicor 904.504 service pack release with no version for 8.03.4x.
Laraine
> > Hi,
> > > Nigel.
> > > > Nigel,
> > > > > Nigel.
> > > > > > Hi,
It should read:
that
version
for 8.03.4x."
Laraine
> Laraine
wrote:
> > > Hi,
yet.
> > > > Nigel.
> > > > > Nigel,
> > > > > > Nigel.
> > > > > > > Hi,
serial numbers.
