BPM for Negative Job Cost Adjustment
We have a BPM that creates a material transaction on a project job when employee expenses are created. I need to create a BPM that will make the same transaction when a job cost adjustment is made so that it creates a negative transaction when the job cost adjustment is negative. I am using the methods for the JobAdjustmentSvcContract. No matter how I try to put the data into the transaction it is always making the cost and quantity positive. The actual job cost adjustment is negative, but I can’t get the code-created transaction to be negative. I have message statements showing the material cost is negative but when I look at the transaction in job tracker it is always positive. Here is the code with messages and my attempts at forcing it to be negative. Is there a different method or something I am missing to have the transaction be negative?
Erp.Contracts.JobEntrySvcContract vh_JobEntry = null;
              vh_JobEntry = Ice.Assemblies.ServiceRenderer.GetService<Erp.Contracts.JobEntrySvcContract>(Db);
              var JobHeadListDS = new Erp.Tablesets.JobHeadListTableset();
              Erp.Contracts.JobAdjustmentSvcContract vh_JobAdjustment = null;
              vh_JobAdjustment = Ice.Assemblies.ServiceRenderer.GetService<Erp.Contracts.JobAdjustmentSvcContract>(Db);
              var JobAdjustmentDS = new Erp.Tablesets.JobAdjustmentTableset();
              jewhereClause = "JobNum='" + ttPartTran_xRow.JobNum + "'";
              jepageSize = 0;
              jeabsolutePage = 0;
              JobHeadListDS = vh_JobEntry.GetList(jewhereClause,
                                                  jepageSize,
                                                  jeabsolutePage,
                                                  out jemorePages);
              var ttJobHeadList_xRow = (from ttJobHeadList_Row in JobHeadListDS.JobHeadList
                                      where string.Equals(ttJobHeadList_Row.Company, Session.CompanyID, StringComparison.OrdinalIgnoreCase)
                                        && ttJobHeadList_Row.JobNum == vJobNum
                                     select ttJobHeadList_Row).FirstOrDefault();
              if (ttJobHeadList_xRow != null)
                  this.PublishInfoMessage("In jobheadlist " ,Ice.Common.BusinessObjectMessageType.Information, Ice.Bpm.InfoMessageDisplayMode.Individual,"", "");
                  Ice.IceRow myttJobsRow  = JobAdjustmentDS.Jobs.NewRow();
                  myttJobsRow["Company"]  = Session.CompanyID;
                  myttJobsRow["JobNum"]   = ttJobHeadList_xRow.JobNum;
                  myttJobsRow["SysRowID"] = ttJobHeadList_xRow.SysRowID;
                  myttJobsRow["RowMod"]   = IceRow.ROWSTATE_UPDATED;
                  JobAdjustmentDS.Jobs.Add(myttJobsRow);
                  vh_JobAdjustment.StartAdjustments(ref JobAdjustmentDS);
                  var ttJATrans_xRow = (from ttJATrans_Row in JobAdjustmentDS.JATrans
                                        where string.Equals(ttJATrans_Row.Company, Session.CompanyID, StringComparison.OrdinalIgnoreCase)
                                          && ttJATrans_Row.JobNum == vJobNum
                                       select ttJATrans_Row).FirstOrDefault();
                  if (ttJATrans_xRow != null)
                      this.PublishInfoMessage("jatrans found " + ttJATrans_xRow.JobNum.ToString(),Ice.Common.BusinessObjectMessageType.Information, Ice.Bpm.InfoMessageDisplayMode.Individual,"", "");
                    ttJATrans_xRow.TranDate = ttPartTran_xRow.TranDate;
                    ttJATrans_xRow.RowMod = IceRow.ROWSTATE_UPDATED;
                  } //if (ttJATrans_xRow != null)
                  vh_JobAdjustment.ChangeMtlAssemSeq(vAssemblySeq,
                  vh_JobAdjustment.ChangeMtlJobMtl(vMtlSeq,
                                      && string.Equals(ttJATrans_Row.RowMod, IceRow.ROWSTATE_UPDATED, StringComparison.OrdinalIgnoreCase)
                    ttJATrans_xRow.TranQty = 1;
                  vh_JobAdjustment.ChangeMtlTranQty(1, ref JobAdjustmentDS);
                      ttJATrans_xRow.MtlBurUnitCost = Math.Round(ttPartTran_xRow.ExtCost * costPctg, 2);
                      if (ttJATrans_xRow.MtlBurUnitCost > 0)
                      //make sure it is negative for the adjustment
                      ttJATrans_xRow.MtlBurUnitCost = ttJATrans_xRow.MtlBurUnitCost * -1;
                      //set the extended cost to the same value to force i
                        this.PublishInfoMessage("values " + ttPartTran_xRow.ExtCost + " " + ttJATrans_xRow.MtlBurUnitCost,Ice.Common.BusinessObjectMessageType.Information, Ice.Bpm.InfoMessageDisplayMode.Individual,"", "");
                  vh_JobAdjustment.CalcUnitCost( ref JobAdjustmentDS);
    //              vh_JobAdjustment.ChangeMtlExtCost(Math.Round(ttPartTran_xRow.ODCUnitCost * costPctg, 2), ref JobAdjustmentDS);
                  vh_JobAdjustment.PreCommitMaterialAdj(ref JobAdjustmentDS,
                                                        out requiresUserInput);
                  vh_JobAdjustment.CommitMaterialAdj(ref JobAdjustmentDS,
                                                    out legalNumberMessage);
I finally found my answer. It turns out that when you call the ChangeMtlTranQty, the first parameter should either be negative or positive, depending on the value of your transaction:
vh_JobAdjustment.ChangeMtlTranQty(-1, ref JobAdjustmentDS);
With the first parameter as positive 1 it is always making the transaction positive. The negative 1 makes the transaction negative.
