BPM Form in the EngWorkBench.CheckOut Method
E10.0.700.2
Does anyone know of an issue with BPM Forms in the EngWorkBench.CheckOut Method?  I am getting the following error:
Error CS1003: Syntax error, ':' expected [EngWorkBench.CheckOut.cs(429,82)]
It seems to reference the following code:
this.ipAsOfDate = Ice.Utility.Serializer.DeserializeDateTime?(stream);
This error occurs as I “Enable” the BPM.  It is triggered when the BPM Form is used.  I moved the form to a different method and it works.  I used forms from other methods that work, so for some reason it is just this method that doesn’t like forms.  When I enable the BPM w/out the form it compiles fine.  There is not custom code per se.  Everything was point and click.
Brenda
