BPM Help please
Thanks Kevin and Jose
That sorted it.
I had a feeling it would be something simple, took me a while to come up with the initial code!
Mark
--- In vantage@yahoogroups.com, "Kevin Simon" <ksimon@...> wrote:
> Mark,
> Before you access the part data, you need to make sure it's available.
> find first ttorderdtl no-lock no-error.
> if available ttorderdtl then do:
> find first part where part.PartNum = ttorderdtl.PartNum no-lock no-error.
> If available part then do:
> if part.Character02 > " " then do:
> {lib/PublishInfoMsg.i &InfoMsg = "part.Character02" }.
> END.
> END.
> END.
> Hope that helps,
> Kevin Simon
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of
> Mark
> Sent: Thursday, February 03, 2011 9:10 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] BPM Help please
> Hi
> I have written a BPM on the SalesOrder.ChangePartNum BO that looks at the
> Part Number entered and if there are comments in the Part.Character02 field
> then it display them as a message in the sales order.
> This works great until someone puts in a part number that doesn't exist in
> the part master, instead a warning is displayed and this Appserver Error is
> created. "'ChangePartNumPre31_A1 bo/SalesOrder.p' Line:5801) ** No Part
> record is available. (91)"
> What adjustment do I need to make to the code to only let it run when the
> part number exists in the part master.
> Code as below:
> END.
> END.
> Thanks
> Mark
Hi
I have written a BPM on the SalesOrder.ChangePartNum BO that looks at the Part Number entered and if there are comments in the Part.Character02 field then it display them as a message in the sales order.
This works great until someone puts in a part number that doesn't exist in the part master, instead a warning is displayed and this Appserver Error is created. "'ChangePartNumPre31_A1 bo/SalesOrder.p' Line:5801) ** No Part record is available. (91)"
What adjustment do I need to make to the code to only let it run when the part number exists in the part master.
Code as below:
END.
END.
Mark
You need another if available then do on the find first part
if available part then do:
END.
END.
END.
*Jose C Gomez*
*Software Engineer*
*T: 904.469.1524 mobile
E: jose@...
http://www.josecgomez.com
On Thu, Feb 3, 2011 at 9:10 AM, Mark <teaglem@...> wrote:
> Hi
> Code as below:
> END.
> END.
> Thanks
> Mark
Mark,
END.
END.
END.
Hope that helps,
Kevin Simon
Mark
Hi
Code as below:
END.
END.
Mark
