Can you set up a BPM message work from the action menu?
Looking to have a BPM message pop up after we generate checks in Payroll.
So usually the Action menu items are calling a process or another Business Object Method.
If you run a trace while selecting that Action menu, you should see what Business Object Method is being called, or if you enable Customization mode, you will get a Message box with which Process ID is being called.
Then you can potentially setup a Post Process Method Directive on that Method to give the message, maybe it needs to check something first and then provide a dynamic message based on the check.
Thanks for the info
