BPM newbie trying to raise exception in MES when materials not i
Yes I did. Thanks.
d, 9/3/08, bdmang_83 <brian.mangan@...> wrote:
Subject: [Vantage] Re: BPM newbie trying to raise exception in MES when materials not issued
Date: Wednesday, September 3, 2008, 9:37 AM
Did you select the enabled checkbox on your directive?
Brian
--- In vantage@yahoogroups .com, Ahmet Erispaha <ahmeterispaha@ ...>
wrote:
> Hi All,
> Â
> I'm trying to write a BPM that raises an exception when a shop
employee clicks OK on the Start Production Activity screen in MES for
an operation that has required materials which have not been issued
in Vantage.
> Â
> Here's what I have done so far:
> 1) To understand the data and build a query phrase with the correct
4GL syntax, I developed a BAQ in Vantage which gives me a list of
LaborDtl rows that are tied to operations which have materials
required but not issued. I had to create my own Field Relations
between LaborDtl and JobMtl. It works and returns the data that I'd
expect.  I'd be glad to send the BAQ Export offline if anyone wants
to take a look.
> Â
> Here is the Query Phrase that Vantage built:
> Â
> for each LaborDtl no-lock , each JobMtl where (Â JobMtl.RequiredQty
> 0 ANDÂ JobMtl.IssuedQty <= 0) and (LaborDtl.Company =
JobMtl.Company and LaborDtl.JobNum = JobMtl.JobNum and
LaborDtl.AssemblySe q = JobMtl.AssemblySeq and LaborDtl.OprSeq =
JobMtl.RelatedOpera tion) no-lock , each JobHead where (Â
JobHead.JobClosed = False) and (LaborDtl.Company = JobHead.Company
and LaborDtl.JobNum = JobHead.JobNum) no-lock
> Â
> Â
> 2) I created a Method Directive with a "number of rows in the
designed query is not less than 1" condition using the query phrase
above (modified to reference ttLaborDtl). Here's the query modified
for the Method Directive condition:
> Â
> for each ttLaborDtl where (ttLaborDtl. RowMod = 'U' or
ttLaborDtl.RowMod = 'A') , each JobMtl where (Â JobMtl.RequiredQty >
0
> Â ANDÂ JobMtl.IssuedQty <= 0)
> Â and (ttLaborDtl. Company = JobMtl.Company
> Â and ttLaborDtl.JobNum = JobMtl.JobNum
> Â ) no-lock ,
> each JobHead where (Â JobHead.JobClosed = False)
> Â and (ttLaborDtl. Company = JobHead.Company
> Â and ttLaborDtl.JobNum = JobHead.JobNum) no-lock
> Â
> The Check Query button says the Query is OK.Â
> Â
> The action for the Method Directive is "raise exception based on
the designed template".
> Â
> 3) When I Log in to MES and test this with a job/operation that has
required materials but none issued, I don't get the popup message
that I'm expecting.
> Â
> Any suggestions as to where I'm going wrong with this would be most
welcome.
> Â
> Many thanks,
> Â Ahmet Erispaha
Hi All,
Â
I'm trying to write a BPM that raises an exception when a shop employee clicks OK on the Start Production Activity screen in MES for an operation that has required materials which have not been issued in Vantage.
Â
1) To understand the data and build a query phrase with the correct 4GL syntax, I developed a BAQ in Vantage which gives me a list of LaborDtl rows that are tied to operations which have materials required but not issued. I had to create my own Field Relations between LaborDtl and JobMtl. It works and returns the data that I'd expect.  I'd be glad to send the BAQ Export offline if anyone wants to take a look.
Â
Â
for each LaborDtl no-lock , each JobMtl where (Â JobMtl.RequiredQty > 0 ANDÂ JobMtl.IssuedQty <= 0) and (LaborDtl.Company = JobMtl.Company and LaborDtl.JobNum = JobMtl.JobNum and LaborDtl.AssemblySeq = JobMtl.AssemblySeq and LaborDtl.OprSeq = JobMtl.RelatedOperation) no-lock , each JobHead where (Â JobHead.JobClosed = False) and (LaborDtl.Company = JobHead.Company and LaborDtl.JobNum = JobHead.JobNum) no-lock
Â
Â
2) I created a Method Directive with a "number of rows in the designed query is not less than 1" condition using the query phrase above (modified to reference ttLaborDtl). Here's the query modified for the Method Directive condition:
Â
for each ttLaborDtl where (ttLaborDtl.RowMod = 'U' or ttLaborDtl.RowMod = 'A') , each JobMtl where (Â JobMtl.RequiredQty > 0
 AND JobMtl.IssuedQty <= 0)
 and (ttLaborDtl.Company = JobMtl.Company
 ) no-lock ,
 and (ttLaborDtl.Company = JobHead.Company
Â
Â
The action for the Method Directive is "raise exception based on the designed template".
Â
3) When I Log in to MES and test this with a job/operation that has required materials but none issued, I don't get the popup message that I'm expecting.
Â
Any suggestions as to where I'm going wrong with this would be most welcome.
Â
Many thanks,
 Ahmet Erispaha
Brian
--- In vantage@yahoogroups.com, Ahmet Erispaha <ahmeterispaha@...>
wrote:
> Hi All,
> Â
in Vantage.
> Â
to take a look.
> Â
> Â
> Â
> Â
> Â
0
> Â and (ttLaborDtl.Company = JobMtl.Company
> Â ) no-lock ,
> Â and (ttLaborDtl.Company = JobHead.Company
> Â
> Â
> Â
that I'm expecting.
> Â
welcome.
> Â
> Many thanks,
> Â Ahmet Erispaha
